Downgrading
Hi
I’m trying to use a custom integration whose developer says isn’t compatible with 2022.4. And so I’m trying to downgrade to an earlier release. Thought I’d found the method and installed the ssh add-on and entered
Ha core update - version 2022.3.8
To which it tells me it’s processing then immediately says “error version 2022.4.6 already installed”
Screenshot enclosed .
Any help would be appreciated.
Screenshot_20220423-075449_kindlephoto-1630089
I should have mentioned its a fresh install and I’m happy completely starting again and doing a fresh flash of my raspberry pi, but i’m pretty new to home assistant
You didn’t quite get the command correct.
ha core update --version 2022.3.8
Note the two dashes and lack of space to version
Brill that seems to be working
I use virtual box, how do I downgrade on virtual box?
same way exact way I believe
I can’t ssh into HA, where exactly do I put the commands.
Install the ssh add-on
afbeelding
All sorted now, it was not the update, I thing I was too quick to restart and too impatient leading to the issues that I had.
