I apologize if this is in the wrong spot, but I am truly at my wits end.
My setup
- HA on docker 2024.11.3
I have a custom bash script that publishes data to the following mqtt topics:
- homeassistant/sensor/cam1/motion
- homeassistant/sensor/cam1/image
- homeassistant/sensor/cam1/video
“motion” is a unix epoch timestamp. “image” and “video” are https URLs.
sensor config in configuration.yaml
mqtt:
- name: Zmodo Cam1Last Motion
state_topic: "homeassistant/sensor/cam1/motion"
device_class: timestamp
value_template: '{{ as_datetime(value) }}'
- name: Zmodo Cam1Video
state_topic: "homeassistant/sensor/cam1/video"
value_template: '{{ value }}'
image:
- name: Zmodo Cam1 Image
url_topic: "homeassistant/sensor/cam1/image"
What is working
- Automation listens on “motion” and sends push notification
- Push notification sends the screenshot using
image: /api/image_proxy/image.zmodo_cam1_image
What I want
Is to send the video
URL to my device. ← This does not work!
I have tried basically everything to no avail. At the very least, how can I use the “Download” integration to download this file then use the media endpoint and pass that into my push notification?
Relevant logs
When attempting to download from URL:
2024-12-03 12:14:02.753 ERROR (MainThread) [homeassistant.components.automation.zmodo_cam1_push_notify] Zmodo Cam1 Push Notify: Error executing script. Invalid data for call_service at pos 2: invalid url for dictionary value @ data['url']
2024-12-03 12:14:02.753 ERROR (MainThread) [homeassistant.components.automation.zmodo_cam1_push_notify] Error while executing automation automation.zmodo_cam1_push_notify: invalid url for dictionary value @ data['url']
Screenshot of downloader in automation
Any tips/tricks are greatly appreciated in advance!!! Thank you all.
