I’m trying to download a file (url retrieve through rest), but, downloader crash because the ssl certificate is not valid .
Is it possible to add an option to disable ssl validation ?
ConnectionError occurred for https://fwcdn.shelly.cloud/gen2/Plus2PM/3767a0b66ea54539b6fe9e41459e118e86ce225744f097a087ef54683e6932fc
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 404, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1060, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 419, in connect
self.sock = ssl_wrap_socket(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/ssl_.py", line 449, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/ssl_.py", line 493, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/local/lib/python3.12/ssl.py", line 455, in wrap_socket
return self.sslsocket_class._create(
File "/usr/local/lib/python3.12/ssl.py", line 1042, in _create
self.do_handshake()
File "/usr/local/lib/python3.12/ssl.py", line 1320, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1000)
My use case is :
- my shelly IOT can’t access the internet, but can access home assistant
- home assistant check the urls to get firmware updates
- download binary to /config/www/shelly/2pm-1.4.2
- send me a notification with the url (my shelly needs passwords)
( I think it can be helpfull if shelly integration do it … but it seems that update url are very different depending of the generation, and I can’t get a way to template this url )
