I have a running instance of Kuna lights that is working & wanted to test the functionality if video stream can be downloaded when motion is detected. So getting mixed results as follows:
downloader:
download_dir: videos
==> the videos are downloaded in this folder but I would like to download video clips using an absolute path that is outside the folder structure of HA installation. I am running HA supervised on a Debian machine where HA is installed at /usr/share/hassio/homeassistant
There is no error so seems like the permission issues are eliminated but no recordings shows up even after two days, where as if I switch back to “download_dir: videos” then the files starts appearing literally within few seconds.
Just to be sure we’re on the same page, you don’t see anything in /tmpin your docker container, right?
Any path specified here will be from docker container perspective.
If you’d want the videos stored somewhere else than in the HA directory, you’d have to “map” that directory from the Host to the HA docker container…
Could I be looking in the wrong container? Here is a list of complete containers.
root@athena:~# docker container ls -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
00f924061ad9 ghcr.io/home-assistant/qemux86-64-homeassistant:2021.6.5 "/init" 2 hours ago Up 2 hours homeassistant
2d13eceec3a1 homeassistant/amd64-hassio-supervisor "/init" 40 hours ago Up 40 hours hassio_supervisor
adab5726c076 ghcr.io/home-assistant/amd64-hassio-observer:2021.06.0 "/init" 2 days ago Up 2 days 0.0.0.0:4357->80/tcp, :::4357->80/tcp hassio_observer
b077b77de50d ghcr.io/home-assistant/amd64-hassio-dns:2021.06.0 "/init" 2 days ago Up 2 days hassio_dns
ff743dda24db ghcr.io/hassio-addons/appdaemon/amd64:0.6.2 "/init" 4 days ago Up 4 days 0.0.0.0:5050->5050/tcp, :::5050->5050/tcp addon_a0d7b954_appdaemon
bae9f47d46c2 ghcr.io/hassio-addons/tasmoadmin/amd64:0.15.0 "/init" 7 days ago Up 7 days 0.0.0.0:9541->9541/tcp, :::9541->9541/tcp addon_a0d7b954_sonweb
42aa948db61c danmed/tasmobackupv1:1.04.13 "/usr/local/bin/dock…" 12 days ago Up 12 days (healthy) 80/tcp addon_9409ee68_tasmobackup
926281a38dd4 ghcr.io/sebclem/hassio-nextcloud-backup/amd64:0.16.1 "/init" 12 days ago Up 12 days addon_229cc4d7_nextcloud_backup
427af5e221ee homeassistant/amd64-addon-ssh:9.1.3 "/init" 12 days ago Up 12 days addon_core_ssh
9835eaa62c86 ghcr.io/hassio-addons/vscode/amd64:3.4.1 "/init" 12 days ago Up 12 days addon_a0d7b954_vscode
18416ebf14f9 homeassistant/amd64-addon-mosquitto:6.0.1 "/init" 12 days ago Up 12 days 0.0.0.0:1883-1884->1883-1884/tcp, :::1883-1884->1883-1884/tcp, 0.0.0.0:8883-8884->8883-8884/tcp, :::8883-8884->8883-8884/tcp addon_core_mosquitto
6cc3a46e142a homeassistant/amd64-hassio-multicast:2021.04.0 "/init" 12 days ago Up 12 days hassio_multicast
1819bd71b5a7 homeassistant/amd64-hassio-cli:2021.05.1 "/init /bin/bash -c …" 12 days ago Up 12 days hassio_cli
1a0fe16c9946 homeassistant/amd64-hassio-audio:2021.04.0 "/init" 12 days ago Up 12 days hassio_audio
d1d8e49d5adf homeassistant/amd64-addon-check_config:3.6.0 "/init" 2 months ago Exited (0) 2 months ago addon_core_check_config
89e3297de80a hello-world "/hello" 2 months ago Exited (0) 2 months ago flamboyant_mirzakhani
c45864d62534 hello-world "/hello" 2 months ago Exited (0) 2 months ago vigorous_kirch
It’s been a long time since the OP, but I recently had the same problem (HA Supervised on Debian 11). I wanted to use a Samba share (mounted to a local folder using cifs) with the Downloader integration.
Folder structure:
ls /usr/share/hassio/ -lh --group-directories-first
total 108K
drwxr-xr-x 6 root root 4.0K Feb 15 21:32 addons
drwxr-xr-x 3 root root 4.0K Feb 15 21:30 apparmor
drwxr-xr-x 4 root root 4.0K Feb 15 21:31 audio
drwxr-xr-x 2 root root 4.0K Feb 27 12:12 backup
drwxr-xr-x 2 root root 4.0K Feb 27 12:15 dns
drwxr-xr-x 10 root root 4.0K Feb 27 13:26 homeassistant
drwxr-xr-x 2 root root 4.0K Feb 15 21:30 media
drwxr-xr-x 7 root root 4.0K Feb 27 11:46 share
drwxr-xr-x 2 root root 4.0K Feb 16 22:11 ssl
drwxr-xr-x 3 root root 4.0K Feb 27 11:17 tmp
The root path of HA seems to be “/usr/share/hassio/”, so I placed the mounted folder inside the share directory. Apparently using something like “…/share/nas_downloads” or “…/share/nas_downloads” for a folder located just outside the config folder does not work.
