I own a Hardkernel Odroid N2+ which is fully updated to the latest version of Home Assistant. I expected to see the “Drag 'n Drop” functionality in the UI, but it is still showing the old version with the position number of a window. I use both Firefox and Safari browsers.
Frankly, I have not the foggiest idea of how this can be; how can this application level functionality be missing when the system is fully opdated?
Yes, the experimental sections are there and that DOES show the new drag 'n drop! But if I create a new view, or want to edit an existing one, all I see are the old minus, plus and enumeration.
Ok, thanks! So apparently the new drag 'n drop is only available for sections, and not even WITHIN sections, as O’ve seen. From the release note I got the impression that this feature was implemented for all views and subviews…
