Drayton Wiser Home Assistant Integration
I do not believe that post is correct either. Many times I sit next to my living room radiator while working on my HA dashboard, and I can hear the itrv valve move incrementally at the same moment I see the radiator demand change in the HA dashboard.
I happen to own 2 of the CCTFR6500. They are not really EU specification, but French specification. The EU is really a combination of the French specification and the German specification, and while most EU male plugs should be compatible with the French specification, unfortunately not all of them are (they lack the hole where the ground prong fits).
See this. Just in case someone needs to know.
I think it must work something like the way you describe it. I have pinched my bioler return temp sensor and attched to the input of the raditaor
It I understand what it is showing, the upward spikes show the valve opening.
The spicks along the top are the boiler cycling
The temp drops slowly once the valve has closed.
At 19:36 another valve was demanding heat for almost the same time.
Why no peak for the 21:00 spike?
I have tried this on other radiators and the temp curves are a lot more messy.
The problem this creates is that you canā€™t say if there is no heat demand and the radiator valve is allowing water through it is not closing properly. You have to wait till the room is a couple of degrees over temp and that can be a long wait in this cold weather
Whilst building plots for ha-wiser in grafana, I have noticed that climate is_heating is not necessarily true when percentage_demand >0.
I see periods in my plots where thereā€™s apparently demand but is_heating remains false. This only happens for some of those very short periods of heating you get as in your plot). Iā€™m not sure if this boolean data is lost due to resampling when generating plotting or the data is not recorded. But it is another reason why I prefer the percentage_demand attribute over the is_heating one as it always seems to reflect call for heat.
Adding LTS Heating demand to the plot it looks as if allowing for thermal delay the valve opens when it goes above zero.
Not sure it closes immediately when heating demand goes back to zero, but it looks like this could be the best guide as to if a valve should be open or not.
Thereā€™s the LTS and there is also the percentage_demand attribute of climate entities.
I assume LTS demand is long term equivalent. The datapoints are fewer and farther between (makes sense as itā€™s LTS).
I am not much cop at lovelace and tend to do it all in grafana. But I believe you can plot attributesā€™ values as well as entity default states in HA graphs.
Again probably off topic, but the config of the Wiser Integration allows the setting of boost values and timing, defaulted to the initial config read from Wiser. Changing the default allows a different boost to that offered by the wiser app which is great.
However, the config screen also allows the input of negative values, which actually is a nice feature, but it doesnā€™t translate into something sent to Wiser. The use case , is something like popping out for a couple of hours, or a temperature hold
Two of my TRVā€™s are eating batteries like cookies. The most distant ones from the Hub. Two days and one battery is gone. So its always the same - one battery is 0% the second is 100%.
Off topic I know, but Ive just seen these things, are they worth it?
We have a solid wall tall ceilings house, anything to increase the heat
A while ago there was a post about ā€œHeating Statsā€ with ā€œHours heating todayā€, ā€œā€¦Yesterdayā€ etc. I am sure that there was something on ā€œRecipesā€ about it , but I cannot find mention of it now apart from this graphic.
Can anyone give me or point me to the code or explain ā€œhow toā€?
Itā€™s definitely in Recipes still
Ahhhā€¦why did I miss itā€¦Iā€™m playing now, Thanks
Sorry to pull on this old reply. Just easier than asking from scratch.
What do you guys do to overcome this issue on rooms you have no room thermostat? Do you use set points higher than ā€œrealā€? Or whatā€™s your take? I honestly do not like the idea of spending money on room thermostats for every room. It feels like the iTRVs were a waste of moneyā€¦
Also a couple additional questions that might be already answered but didnā€™t manage to find with the search.
  1. Is there a way to get entities for the iTRVs temperature for rooms that have multiTRVs? Iā€™m sure you know what I mean. I have a large room with 3 iTRVs AND the room thermostat. I know/guess the roomstat takes priority and is used as the ā€œroom temperatureā€ and iTRVs get ignored. Thatā€™s fine. But is there a way (for science) to check on the iTRVs individual entities?
  2. Do iTRVs report on the % of valve open? How can we make sure they are indeed working properly and not need calibration?
Many thanks for the awesome thread activity too.
Iā€™ve got reflectors behind all my radiators - they were cheap and unobtrusive, so thought nothing to lose. Do they help? No idea!
My parents have the radfans on a couple of their radiators. You can definitely feel the heat from them, but they are quite noisy (especially in a quiet room), and of course you have the running costs.
Not used the deflectors, but I have wanted something like that for ages as we have a rad under our worktop in the kitchen, so the room is freezing and the worktop is toasty warm, so just about to order one to try!
Hey,
I used a real thermometer to work out the room temp and then just set the temp +1-2C higher, We have high ceilings (3m) so not surprised the trvs get confused.
If you look in the recipes section wiserHomeAssistantPlatform/recipes/linking_3rd_party_sensors_to_wiser_heating.md at 6549411942e8c5e99b6fa63988b109c15fe7b8c6 Ā· asantaga/wiserHomeAssistantPlatform Ā· GitHub we have some documentation showing how you can use another temp sensor (sonoff/aquara etc) to boost the room so that it reaches the true temp. The real fix is for Drayton Wiser to offer an ā€œoffsetā€ value , they are aware of this and it is on the roadmapā€¦
Well , ive ordered foil, quite cheap and then i might get some passive reflectors. The ones with fans claim to be quiet , obviously not!
Will want to hear your thoughts when installed. If you feel an improvement I might order some too. My living room is large and struggles heating up even with 3 rads.
Battery level stats are mostly went out. I think after last update of 9.3.
Thereā€™s measuring the temp in an appropriate location and then thereā€™s sensor issues. Weā€™ve had a couple of old school thermometers on the walls for years. One is mercury. They always agree with each other to within half degree C when set next to one another. That doesnā€™t of course mean their right!
I compared one of them with a wiser roomstat, a wiser iTRV, a homemade BME280 sensor (esphome) and temp readout of an old currentcost meter I have.
The wiser roomstat always agreed well with the thermometer.
The rest were all over the place and could not be brought inline with a fixed offset. Iā€™m wondering if the RH sensor in the roomstat is also as good.
Some of these sensors offer precision that belies their (in)accuracy :grinning:
You can potentially calibrate your old school mercury thermometers and use them as reference to see how accurate the others are. This is what I did and then I created template sensors to calibrate all my zigbee thermometers. :slight_smile:
