I have recently re-installed my entire setup, mainly due to bloat and a lot of experimental mistakes when I installed about a year ago.
After recreating a new image on the SD card I have started to add in all my Zigbee devices. In the large part all ok until I started to add in my Drayton Wiser TRV’s.
Shortly after adding I receive the following error message in the logs, I have done some research but cannot locate anything that helps. The error messages are:
z2m: Failed to configure ‘TRV_Bedroom_H’, attempt 4 (Error: Bind 0xb43522fffeb0c141/1 genPowerCfg from ‘0x00124b0029e8bec1/1’ failed (ZDO error: bind failed with status ‘TABLE_FULL’ (140)) at /app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:1126:36)
Has anyone seen or have an idea about this.
Appreciate any guidance.
