Seen plenty of comparisons online, but none specifically geared towards this community. I’m not talking about pulling apart the systems either; I’m talking about still allowing them to control their relevant ecosystems but with the odd HA setting tweak/status read here and there.
My goal is maximising the efficiency of my new boiler. My original plan was on/off relays for the boiler and hacked Zigbee TRVs (via deCONZ) with HA having full control. Since I’ve learned about burner modulation, condensing temperatures, optimum starts, weather compensation etc I’ve realised I don’t have a chance at programming something as good as the smart stats.
I considered an Opentherm gateway from Nodo but I won’t get TRV support/room zoning.
For me, winners:
Price - Wiser
HA integration - Wiser
TRV battery life - Evohome
Use of system without smartphone app - Evohome
On the face of it you’d think it’s 2-2 BUT:
Is the Opentherm support as good on the Wiser? You’d think so when reading their blogs, seems they have optimum start/stop, burner modulation, weather compensation via online outdoor temp readings etc.
How good does it work offline/not connected to the cloud, what functionality is lost? (Excluding their own geofencing/anything HA can do with relevent integrations).
Which system is more likely to break HA integration via firmware update etc?
Looks like development for integrations is currently more active for Wiser.
Then how about the fact that Evohome is on 868Mhz, Wiser on 2.4Ghz Zigbee? I already have a Zigbee network it needs to avoid, plus Wifi on two of the three channels - asking for trouble?!
Would be nice to make sure before spending £500+.
Boiler is Ideal Vogue Max 40.
Thanks!
