I know I’m not alone in forgetting to drink water sometimes (I’m looking at you, fellow ADHD friends). So in the spirit of better health, I decided to automate a bit of my daily life with a regular reminder to drink water, when it’s been a while.
The basic premise is there is a date/time helper to track the last time you’ve drank water. After a configurable number of hours, you’ll get a notification to drink water. You can update the tracker right from the notification, or snooze it to be reminded later. You can set how long it is until you’re notified, and optionally get notified every subsequent hour until the tracker is updated. You can also configure during what times during the day notifications will be sent.
To use this blueprint you’ll need a few things:
- A mobile device running the Home Assistant app.
- Create a “Date and/or time” helper set to “Date and Time”.
- Create a button helper (to manually trigger the automation).
- Create a timer helper, set to the duration you wish your snooze time to be. 10-30 minutes is recommended. Can’t be longer than 59 minutes.
If you want to get even fancier and have an NFC tag to scan on your water bottle, or any other trigger you can dream up, just create another automation with the NFC tag as a trigger. In the actions, create a service call to Input Button: Press and select the button helper you created in step 3. Or add a button widget to your phone’s home screen.
This is my first blueprint. Please let me know if you have any feedback. I hope this is able to help others with their mental and physical health.
blueprint:
name: Drinking Water Tracker & Reminder
description:
"Track your water drinking and remind yourself when you haven't for
a while. This blueprint requires you to create 3 input helpers: Date & Time, Button,
and Timer."
source_url: https://gist.github.com/djahren/322ce13a857b2099956429005669fe4a
domain: automation
input:
notify_device:
name: Device to notify
description:
Device needs to run the Home Assistant app to receive actionable
notifications.
selector:
device:
integration: mobile_app
multiple: false
last_drank_helper:
name: Date and Time Helper
description:
Create a Date and Time helper to track the last time you drank
water.
selector:
entity:
domain: input_datetime
multiple: false
drank_water_button_helper:
name: Drank Water Button Helper
description:
"Create a button helper to press indicating you've drank water.
This can also be added as a widget on your phone's home screen.
To create more triggers (such as an NFC tag on your water bottle), create
a new automation with your desired triggers and use the Call Service action,
calling the Input Button: Press service."
selector:
entity:
domain: input_button
multiple: false
snooze_timer_helper:
name: Snooze Timer Helper
description:
Create a timer helper that is set to the duration you'd like to
snooze notifications for. Reccomended between 10 and 30 minutes.
selector:
entity:
domain: timer
multiple: false
reminder_delay:
description: Number of hours after drinking water to send a reminder.
default: 4
selector:
number:
min: 1.0
max: 12.0
mode: slider
step: 1.0
repeat_every_hour:
name: Repeat Every Hour
description:
This will repeat a reminder every hour (between the times specified
below) until the water tracking helper is updated. This won't create multiple
notifications, only update an existing one.
default: true
selector:
boolean: {}
reminder_start_time:
name: Reminder Start Time
description: Don't send reminders before this time.
default: "10:00"
selector:
time: {}
reminder_end_time:
name: Reminder End Time
description: Don't send reminders after this time.
default: "22:00"
selector:
time: {}
mode: parallel
max_exceeded: silent
- platform: state
entity_id:
- !input drank_water_button_helper
- platform: time_pattern
minutes: "*"
- platform: event
event_type: mobile_app_notification_action
event_data:
tag: drink-water-reminder
- platform: state
entity_id:
- !input snooze_timer_helper
to: idle
variables:
last_drank_helper_id: !input last_drank_helper
reminder_delay: !input reminder_delay
repeat_every_hour: !input repeat_every_hour
timer_helper: !input snooze_timer_helper
uid: "{{ this.entity_id.split('.')[1].upper() }}"
drank_water_action: DRANK_WATER_{{ uid }}
water_snooze_action: WATER_SNOOZE_{{ uid }}
"{{ trigger.event.data.action if trigger.id == 'notification_action' else
snooze_minutes:
snooze_minutes: '{{ state_attr(timer_helper, "duration").split(":")[1] }}'
run_reminder:
"{% set delay = reminder_delay|int %}{% set repeat = repeat_every_hour|bool
%} {% set time_since = now().replace(tzinfo=None) - (states(last_drank_helper_id)
| as_datetime).replace(tzinfo=None) %} {% set hours_ago = time_since.seconds //
3600 + time_since.days * 24 %} {% set remaining_minutes = time_since.seconds //
60 %} {% if hours_ago < delay %}off{% else %} {{ remaining_minutes % 60 == 0 and
(repeat or (not repeat and hours_ago == delay)) }} {% endif %}"
condition:
- condition: template
value_template: '{{ trigger.id != "every_minute" or run_reminder }}'
- choose:
- conditions:
- condition: or
conditions:
- condition: and
conditions:
- condition: trigger
value_template: "{{ run_reminder }}"
- condition: time
after: !input reminder_start_time
before: !input reminder_end_time
sequence:
- type: notify
domain: mobile_app
device_id: !input notify_device
message:
You last drank water {{ states(last_drank_helper_id) | as_datetime
| relative_time}} ago. Drink more now?
actions:
- action: "{{ drank_water_action }}"
title: "I drank some! \U0001F4A7"
- action: "{{ water_snooze_action }}"
title: Snooze ({{snooze_minutes}}m)
- conditions:
value_template: "{{ action == water_snooze_action }}"
sequence:
- service: timer.start
data: {}
entity_id: !input snooze_timer_helper
- conditions:
- condition: or
conditions:
value_template: "{{ action == drank_water_action }}"
sequence:
- service: input_datetime.set_datetime
timestamp: "{{as_timestamp(now())}}"
entity_id: !input last_drank_helper
- type: notify
domain: mobile_app
message: clear_notification
