Do you mean that? I inserted a delay for each smitch but it does not make a difference
[{"id":"e3db9c9daedf9bd1","type":"api-call-service","z":"c753663a45a2236f","name":"Hochbeet","server":"92183824.74a3e8","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":["b67eb5c4b798ff3c71fa4c4e8dfb9e1c"],"entityId":["switch.rasen_esp8266_tropf_hochbeet_4"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":520,"y":100,"wires":[["11748743f20a41d4"]]},{"id":"9288700f1e594308","type":"api-call-service","z":"c753663a45a2236f","name":"Haus","server":"92183824.74a3e8","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.rasen_esp8266_tropf_haus_3"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":510,"y":200,"wires":[["11748743f20a41d4"]]},{"id":"82a824d3d32997c2","type":"api-call-service","z":"c753663a45a2236f","name":"Terasse","server":"92183824.74a3e8","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.rasen_esp8266_tropf_terrasse_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":520,"y":160,"wires":[["11748743f20a41d4"]]},{"id":"11748743f20a41d4","type":"delay","z":"c753663a45a2236f","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":750,"y":140,"wires":[["f4c074c69a108eaf","3f4120f883bbad83","ee9b48a4771033a5","ec0170732f253208"]]},{"id":"f4c074c69a108eaf","type":"api-call-service","z":"c753663a45a2236f","name":"Hochbeet","server":"92183824.74a3e8","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.rasen_esp8266_tropf_hochbeet_4"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":940,"y":80,"wires":[[]]},{"id":"3f4120f883bbad83","type":"api-call-service","z":"c753663a45a2236f","name":"Terasse","server":"92183824.74a3e8","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.rasen_esp8266_tropf_terrasse_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":940,"y":140,"wires":[[]]},{"id":"ee9b48a4771033a5","type":"api-call-service","z":"c753663a45a2236f","name":"Haus","server":"92183824.74a3e8","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.rasen_esp8266_tropf_haus_3"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":930,"y":200,"wires":[[]]},{"id":"ec0170732f253208","type":"api-call-service","z":"c753663a45a2236f","name":"Tropfautomatik","server":"92183824.74a3e8","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.tropfbewasserung"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":960,"y":260,"wires":[[]]},{"id":"7a1e30717dacf86f","type":"server-state-changed","z":"c753663a45a2236f","name":"Tropfautomatik","server":"92183824.74a3e8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.tropfbewasserung","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"On","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":80,"y":140,"wires":[["31a131fe2153952f","7d93c576684cc313","2f9a77c2346b91fd"],[]]},{"id":"31a131fe2153952f","type":"delay","z":"c753663a45a2236f","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":300,"y":220,"wires":[["e3db9c9daedf9bd1","9288700f1e594308"]]},{"id":"2f9a77c2346b91fd","type":"delay","z":"c753663a45a2236f","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":300,"y":160,"wires":[["82a824d3d32997c2"]]},{"id":"7d93c576684cc313","type":"delay","z":"c753663a45a2236f","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":300,"y":100,"wires":[["e3db9c9daedf9bd1"]]},{"id":"92183824.74a3e8","type":"server","name":"Home Assistant","addon":true}]
To me that looks awful to read
I shall give it a closer look this evening. But thanks so far
