Drivvo Sensor Component
Custom component to obtain information present in drivvo.com for the home assistant.
Install
HACS
- Have HACS installed, this will allow you to update easily.
- Add GitHub - hudsonbrendon/sensor.drivvo: Custom component for information about your car's status available on drivvo.com for the home assistant as a custom repository of Type: Integration
- Click Install on the “Drivvo” integration.
- Restart Home-Assistant.
Manual
- Copy the custom_components/drivvo directory to your /custom_components directory.
- Configure.
- Restart the Home Assistant.
Configuration
Adding Drivvo to your Home Assistant instance can be done via the UI using this button:
Manual Configuration
If the My button above doesn’t work, you can also perform the following steps manually:
- Navigate to your Home Assistant instance.
- In the sidebar, click Settings.
- From the Setup menu, select: Devices & Services.
- In the lower right corner, click the Add integration button.
- In the list, search and select “Drivvo”.
- Follow the on-screen instructions to complete the setup.
Make a card
To view drivvo information, follow an example of a card. Remember to replace the entities present on the card with your entities.
type: custom:config-template-card
entities:
- sensor.nissan_march_abastecimento
card:
type: entities
show_header_toggle: 'off'
style: |
.card-header {
padding: 0px 0px 0px 0px !important;
entities:
- type: custom:hui-vertical-stack-card
cards:
- type: horizontal-stack
cards:
- type: picture
style: |
ha-card {
--paper-card-background-color: 'rgba(0, 0, 0, 0.0)';
--ha-card-background: "rgba(0, 0, 0, 0.0)";
--ha-card-box-shadow: 'none';
image: /local/images/nissan.png
- type: custom:button-card
layout: icon_name_state2nd
show_icon: true
show_state: true
styles:
grid:
- grid-template-columns: 50px auto
icon:
- padding: 0px 0px
- height: 100px
- width: 30px
card:
- '--ha-card-background': rgba(0, 0, 0, 0.0)
- '--ha-card-box-shadow': none
state:
- padding: 0px 10px
- justify-self: start
- font-family: Roboto, sans-serif
- font-size: 15px
name:
- padding: 0px 10px
- color: var(--secondary-text-color)
entity: device_tracker.nissan_march
icon: mdi:car
- type: custom:bar-card
show_icon: true
align: split
columns: 1
max: 41
positions:
icon: inside
indicator: inside
value: inside
unit_of_measurement: Litros
animation: 'on'
severity:
- color: '#fd0000'
to: 19
- color: '#ffaa00'
to: 29
- color: '#2CE026'
to: 41
style: |
ha-card {
--paper-item-icon-color: 'var(--text-primary-color';
entities:
- entity: sensor.nissan_march_abastecimento
attribute: volume_de_combustivel
name: Volume de combustível
entity_row: true
- type: custom:apexcharts-card
chart_type: line
header:
title: Nissan March
show: true
show_states: true
colorize_states: true
series:
attribute: odometro
type: column
unit: km
attribute: preco_do_combustivel
type: column
name: Preço atual da gasolina
unit: R$
float_precision: 2
attribute: valor_total_pago
type: column
name: Valor total pago
unit: R$
float_precision: 2
attribute: soma_total_de_valores_pagos_em_todos_os_abastecimentos
type: column
name: Total pago em todos os abestecimentos até então
unit: R$
float_precision: 2
attribute: km_percorridos_desde_o_ultimo_abastecimento
type: column
name: Kms percorridos desde o último abastecimento
unit: Km
- entity: sensor.gasolina_media_natal
type: column
name: Preço médio da gasolina
unit: R$
float_precision: 2
type: column
unit: Abastecimentos
After setup, the card above will look like this:
Debugging
logger:
default: info
logs:
custom_components.drivvo: debug
