Drop support for armhf & i386 node red 15.0.0
The newest update for node red tells:
What’s changed
This release drops support for the armhf and i386 CPU platforms.
:rotating_light: Breaking changes
Drop support for armhf & i386 @frenck (#1718)
:arrow_up: Dependency updates
:arrow_up: Update ghcr.io/hassio-addons/base Docker tag to v14.3.0 @renovate (#1717)
:arrow_up: Update ghcr.io/hassio-addons/base Docker tag to v14.3.1 @renovate (#1720)
:arrow_up: Update @node-red-contrib-themes/theme-collection to v3.1.5 @renovate (#1722)
You have 14.6.3 installed. Click update to update to version 15.0.0
What does “drop i386” mean? I run HassOS as a VM on ESXi on a NUC which runs on top of an x386… what does i386 mean? Is it safe to upgrade?
You most likely run a 64bit system, which is named amd64
i386 = 32bit Intel & AMD
armhf = 32bit ARM
So they dropped support for 32bit platforms.
Thanks, clear I updated succesfully.
