Hey everyone,
in order to make the 3 pages of my e-ink display manually and automated triggerable from within HA, I created a dropdown helper with the values page1, page2 and page3. That helper is “imported” to my esphome node via a HA textsensor, and is then used to switch between the pages.
Problem: that only works very unreliably. Most of the times I switch between pages via the dropdown, esphome node actually registers the changed value, triggers a display redraw, BUT: the page doesn’t actually change on the physical display.
Setup within HA for manual switching within the dashboard:
Automation linked to a Tradfri button:
Example log output from esphome (the red changes redraw the display without changing the page, the green one works as expected and shows page2 on the physical display. The number of back and forth needed to get a successful change is random, no pattern recognizable so far):
The yaml of the node:
esphome:
esp32:
board: esp32doit-devkit-v1
framework:
type: arduino
# Enable logging
logger:
json:
# Enable Home Assistant API
api:
password: ""
ota:
password: ""
wifi:
ssid: "XXXXXXX"
password: "XXXXXXXX"
ap:
ssid: "Epaper Fallback Hotspot"
password: "XXXXXXX"
captive_portal:
font:
- file: 'arial.ttf'
- file: 'arial.ttf'
image:
- file: "otter.bmp"
resize: 296x128
- file: "otterbitmap2.bmp"
- file: "otter_complete.bmp"
time:
- platform: homeassistant
entity_id: weather.home
internal: true
attribute: temperature
text_sensor:
internal: true
entity_id: weather.openweathermap
internal: true
attribute: forecast
entity_id: input_select.epaper_page
on_value:
then:
- display.page.show: !lambda |-
if (id(pages).state == "page1") {
return page1;
else if (id(pages).state == "page2") {
return page2;
else {
return page3;
- component.update: eink
internal: true
spi:
clk_pin: 19
mosi_pin: 18
display:
- platform: waveshare_epaper
cs_pin: 21
dc_pin: 3
busy_pin: 22
reset_pin: 1
model: 2.90inv2
rotation: 90°
update_interval: 1800s
full_update_every: 1
#reset_duration: 2ms
pages:
- id: page1
lambda: |-
it.image(0, 0, id(otter_complete));
it.printf(80, 0, id(font1), "Hey, it is");
if (id(outside_temperature).has_state()) {
it.printf(80, 20, id(font2), "%.1f", id(outside_temperature).state);
it.printf(80, 50, id(font1), "degrees outside");
it.printf(80, 70, id(font1), "and it is");
if (id(outside_weather).has_state()) {
it.printf(80, 90, id(font2), "%s", id(outside_weather).state.c_str());
- id: page2
lambda: |-
it.printf(0, 0, id(font1), "page2");
if (id(owm_forecast).has_state())
DynamicJsonDocument doc(2048);
deserializeJson(doc, (id(owm_forecast).state.c_str()));
JsonArray root = doc.as<JsonArray>();
JsonObject root_0 = root[0];
float root_0_precipitation = root_0["precipitation"];
it.printf(0,20, id(font1), "%.0f mm", root_0_precipitation);
- id: page3
lambda: |-
it.printf(0, 0, id(font1), "page3");
The whole compiling and flashing (via esphome commandline on windows10) goes through without a single warning or anything. Am I missing something here? Or is there a different approach (than the dropdown helper) to address esphome display pages from within HA that works both for manual dashboard changes AND automations?
Thanks a lot in advance!
