Hi folks,
I am using a mushroom-select-card to configure a timer for the heating in my bathroom. Could also be used for any other timed activities.
Workflow:
The mushroom dropdown triggers & sets the value for a timer helper and then starts the heating for the selected time duration. Once the set time is over the heating stops and timer & dropdown will be reset.
@Didgeridrew helped a lot here and I think this is worth sharing with others. Could also probably be worth creating a Blueprint for this - which is beyond my skills.
Follow the solution for details and code example.
This is a general automation to control a heater based on a select and a timer⌠you will need to provide your select option value details and entity names for something more specific.
- platform: state
entity_id: input_select.heater_time
- platform: event
event_type:
- timer.cancelled
- timer.finished
event_data:
entity_id: timer.heat_timer
- platform: event
event_type:
- timer.start
event_data:
condition:
- choose:
- conditions:
- condition: trigger
sequence:
- service: timer.start
duration: "{{ trigger.to_state.state }}{# MORE INFO REQUIRED #}"
- entity_id: timer.heat_timer
- conditions:
sequence:
- service: climate.turn_on
default:
- service: climate.turn_off
mode: queued
Thanks Drew,
I also tried the âoptionsâ path but my skills are not high enough so tried the if/else which also didnât work.
My dropdown is called âinput_select.dropdown_bad_heizen_timerâ and the HVAC entity is called âclimate.badezimmerâ.
For the 1/2/3 hrs I configured 3 different timers - not sure if this is needed or if one single timer can be configured based on the value of the input select.
My timers are called âtimer.heizung_bad_1h_timerâ and then âŚ2h / âŚ3h.
I configured a new Automation and will try to adapt the code you shared.
Ok, updated the automation based on your code example, still needs more refinement and I donât see the 3 different timer options & off reflected.
- platform: state
entity_id:
- input_select.dropdown_bad_heizen_timer
- platform: event
event_type:
- timer.cancelled
- timer.finished
event_data:
entity_id: timer.heizung_bad_1h_timer
- platform: event
event_type:
- timer.start
event_data:
condition: null
- choose:
- conditions:
sequence:
- entity_id: timer.heizung_bad_1h_timer
- conditions:
sequence:
- service: climate.set_temperature
temperature: 24
entity_id: climate.badezimmer
default:
data: {}
mode: queued
A single timer should be sufficient, and will keep the automation a lot simpler.
What are the values of your selectâs options? Are they just â1â, â2â, â3â or something like â1 hourâ, â2 hoursâ, â3 hoursâ? We will need to know that to correctly design the template to assign the timerâs duration.
The options are âAusâ (German for off), â1hâ, â2hâ, â3hâ.
- platform: state
entity_id:
not_from:
- unavailable
- platform: event
event_type:
- timer.cancelled
- timer.finished
event_data:
- platform: event
event_type:
- timer.start
event_data:
condition: []
- choose:
- conditions:
- condition: template
value_template: "{{ trigger.to_state.state in ['1h', '2h', '3h'] }}"
sequence:
duration: >
{{ trigger.to_state.state | replace('h', '') | int * 3600 }}
- conditions:
sequence:
temperature: 24
default:
data: {}
mode: queued
When I try to safe, following error message is being displayed:
Message malformed: expected a dictionary for dictionary value @ data[âactionâ][0][âchooseâ][0][âsequenceâ][0][âtargetâ]
The entity id should not have the -
in front of itâŚ
sequence:
duration: >
EDIT: I have fixed it in the previous post as well
I can save the automation and when I change values in the dropdown from within the dashboard I see coresponding entries in the logbook, but the HVAC devices does not change to heating or sets the new temperature.
I also added the HVAC mode âheatâ to the yaml, but that does not seem to have any effect.
Trying to troubleshoot through the logs & tracing - the latter isnât intuitive enough for my skill level.
I understand from the trace that the timer started, but the heating would be started through the middle branch, which as I get it did not get followed.
You should have had another trace after that when the timer turning on triggers the climate actionâŚ
It looks like I messed up the start event trigger. The event type should have been timer.restarted
- platform: event
event_type:
- timer.restarted
event_data:
That seems to work. I will test it today and share feedback tonight.
So this basically works, but there seems to be still a bug.
I had the timer running this morning and it worked, switched of the heating after 1hr.
After finishing, the dropdown stayed at 1hr (would be cool if it would switch back to âAUSâ resp. âOFFâ after the timer has finished).
Later today I switched the drop down to âAUSâ and back to 1hr this evening. And it looks the process went again with the left branch and started only the timer, but not the heating.
For reference this is the current code:
I renamed the timer since it is can handle multiple hour values as I understand it and deleted the other 2hr and 3hr timers.
alias: Heizung - Bad Timer Steuerung
description: ""
- platform: state
entity_id:
not_from:
- unavailable
- platform: event
event_type:
- timer.cancelled
- timer.finished
event_data:
entity_id: timer.heizung_bad_timer
- platform: event
event_type:
- timer.restarted
event_data:
condition: []
- choose:
- conditions:
sequence:
duration: |
- conditions:
sequence:
temperature: 24
hvac_mode: heat
default:
data: {}
mode: queued
description: ""
- platform: state
entity_id:
not_from:
- unavailable
- platform: event
event_type:
- timer.cancelled
- timer.finished
event_data:
- platform: event
event_type:
- timer.restarted
event_data:
- platform: state
to: 'off'
not_from:
- unknown
- unavailable
condition: []
- choose:
- conditions:
sequence:
duration: |
- conditions:
sequence:
temperature: 24
hvac_mode: heat
- conditions:
sequence:
- service: input_select.select_option
entity_id: input_select.dropdown_bad_heizen_timer
option: Aus
default:
- "{{ not is_state('climate.badezimmer', ['off', 'unknown', 'unavailable']) }}"
data: {}
mode: queued
max: 2
This throws the error message âMessage malformed: expected dictionary @ data[âactionâ][0][âdefaultâ][0]â
I compared both old and new code and also validated the new yaml - still cannot make up where the error in the code is. Guess in the action section?
I changed the last options (4) default parameter through the GUI and so far the automation works.
However, I think I catched one bug, which is when the timer is off and I change the dropdown to 1h it does not always start the heating immediately. When I change it to 2hrs and back to 1hr it works.
Current code:
description: ""
- platform: state
entity_id:
not_from:
- unavailable
- platform: event
event_type:
- timer.cancelled
- timer.finished
event_data:
- platform: event
event_type:
- timer.restarted
event_data:
- platform: state
to: "off"
not_from:
- unknown
- unavailable
condition: []
- choose:
- conditions:
sequence:
duration: |
- conditions:
sequence:
temperature: 24
hvac_mode: heat
- conditions:
sequence:
option: Aus
default:
data: {}
mode: queued
max: 2
That is because I accidentally left out the timer.started
option of the timer_start
trigger⌠both started
and restarted
are required so that it works when the timer goes from idle to active as well as when the timer is already active and the duration is changed.
description: ""
- platform: state
entity_id:
not_from:
- unavailable
- platform: event
event_type:
- timer.cancelled
- timer.finished
event_data:
- platform: event
event_type:
- timer.started
- timer.restarted
event_data:
- platform: state
to: "off"
not_from:
- unknown
- unavailable
condition: []
- choose:
- conditions:
value_template: "{{ trigger.to_state.state | replace('h', '') | is_number}}"
sequence:
duration: |
- conditions:
sequence:
temperature: 24
hvac_mode: heat
- conditions:
sequence:
option: Aus
default:
- condition: "{{ not is_state('climate.badezimmer', [ 'off', 'unavailable', 'unknown' ]) }}"
data: {}
mode: queued
max: 2
Thanks much @Didgeridrew. So far this is working as expected! Iâll update the original post.
