I have been running home assistant with my aqara m2 hub for a couple months now and has been working great. The past week I have had a couple instances when home assistant stops getting updates from any of the aqara sensors.
The aqara app shows the sensors working and reporting fine. But the sensors in home assistant shows the same value as when it stopped reporting. The history graph shows data updates up until the crash and then its a straight line.
Other non aqara sensors and devices work OK at this point and only a restart of home assistant brings the aqara sensors back online. They don’t report as missing or errored, just no data updates.
I looked in the logs and saw the following:
2021-04-09 19:00:52 ERROR (zeroconf-ServiceBrowser__hap._tcp.local._3945363) [root] Uncaught thread exception#033[0m
File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/srv/homeassistant/lib/python3.8/site-packages/zeroconf/__init__.py", line 1755, in run
self._service_state_changed.fire
File "/srv/homeassistant/lib/python3.8/site-packages/zeroconf/__init__.py", line 1513, in fire
h(**kwargs)
File "/srv/homeassistant/lib/python3.8/site-packages/zeroconf/__init__.py", line 1611, in on_change
listener.add_service(*args) File "/srv/homeassistant/lib/python3.8/site-packages/aiohomekit/zeroconf/__init__.py", line 80, in add_service
if info.properties[b"id"].decode() == self._device_id:
KeyError: b'id'
Then, every minute it has the following:
File "/srv/homeassistant/lib/python3.8/site-packages/aiohomekit/controller/ip/connection.py", line 512, in _reconnect
return await self._connect_once() File "/srv/homeassistant/lib/python3.8/site-packages/aiohomekit/controller/ip/connection.py", line 572, in _connect_once
self.host, self.port = await async_find_device_ip_and_port(
File "/srv/homeassistant/lib/python3.8/site-packages/aiohomekit/zeroconf/__init__.py", line 281, in async_find_device_ip_and_port
data = await loop.run_in_executor(
File "/usr/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/srv/homeassistant/lib/python3.8/site-packages/aiohomekit/zeroconf/__init__.py", line 266, in _find_data_for_device_id
if info.properties[b"id"].decode() == device_id:
KeyError: b'id'
This is quite frustrating as I thought it may be a network issue but as I can still use the aqara app OK, and within the aqara app I don’t see any missing data, along with a home assistant service restart only, makes me wonder if it’s a bug in home assistant that should be recoverable.
Any help would be appreciated as all I can think of next is to have a scrip monitoring the error log and have it restart home assistant. Not very elegant
