Dropping message with invalid payload Causing Controller to Jam
I’ve been having this issue for weeks now but recently I have added an about 8 more of the Zooz Zen30 double switches and now the controller gets jammed within a few minutes of a restart. The logs are attached but I don’t know how to fix the issue.
2024-04-24T04:01:27.588Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:27.609Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:27.862Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:27.894Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:27.903Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:27.908Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:28.105Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:28.359Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:28.380Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:28.384Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-04-24T04:01:28.472Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:28.498Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:28.503Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:28.510Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:28.641Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:28.786Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:28.809Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:28.906Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.158Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:29.183Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:29.190Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.195Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:29.201Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.235Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.244Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.268Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.337Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.383Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.389Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.409Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.473Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.489Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.570Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.591Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.723Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:29.756Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.010Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:30.032Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:30.041Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.045Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:30.093Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.131Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.333Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.345Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.482Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.500Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.610Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.635Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.669Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.782Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.789Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:30.808Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:31.043Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:31.066Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:31.184Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:31.357Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:31.381Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:31.634Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:31.655Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:31.892Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:31.900Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:32.071Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:32.217Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:32.415Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:32.667Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:32.687Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:50.541Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:50.546Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:50.799Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:50.820Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:50.843Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:50.850Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:51.061Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:51.314Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:51.335Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:51.368Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:51.376Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:51.444Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:51.467Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:51.590Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:51.745Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:51.768Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.021Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:52.049Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:52.122Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.133Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:52.142Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.181Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.206Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.228Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.340Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.592Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:52.613Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:52.657Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.666Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:52.672Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.676Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.692Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.714Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:52.966Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:52.993Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:53.016Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:53.023Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:53.035Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:53.287Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:53.307Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:53.703Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:53.712Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:53.782Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:54.035Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:54.054Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:54.100Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:54.113Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:54.118Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:54.134Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:54.387Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:54.408Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:54.439Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:54.446Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:54.699Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:54.718Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:54.772Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:54.782Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:55.035Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:55.054Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:55.165Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:55.174Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:55.428Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:55.448Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:01:55.537Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:01:55.544Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:01:55.795Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:01:55.817Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:33.532Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:33.539Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:33.793Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:33.818Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:33.858Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:33.865Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:34.032Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:34.284Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:34.311Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:34.380Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:34.386Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:34.430Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:34.452Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:34.643Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:34.758Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:34.779Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:34.881Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.089Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.130Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.165Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.190Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.211Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.234Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.381Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.401Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.577Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.598Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.737Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:35.759Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:36.012Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:36.034Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:36.692Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:36.700Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:36.952Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:36.973Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:37.052Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:37.062Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:37.093Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:37.116Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:37.368Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:37.388Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:37.447Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:37.452Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:37.705Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:37.731Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:37.789Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:37.792Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:38.045Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:38.065Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:38.076Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:38.081Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:38.333Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:38.349Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:02:38.421Z CNTRLR « [Node 127] received wakeup notification
2024-04-24T04:02:38.430Z CNTRLR   [Node 127] The node is now awake.
2024-04-24T04:02:38.683Z CNTRLR » [Node 127] Sending node back to sleep...
2024-04-24T04:02:38.699Z CNTRLR   [Node 127] The node is now asleep.
2024-04-24T04:04:31.035Z CNTRLR » [Node 108] Multilevel Sensor CC values may be stale, refreshing...
2024-04-24T04:04:31.037Z CNTRLR » [Node 108] querying Air temperature sensor reading...
2024-04-24T04:04:31.067Z CNTRLR   The controller is jammed
2024-04-24T04:04:35.148Z CNTRLR   The controller is no longer jammed
2024-04-24T04:04:35.152Z CNTRLR   [Node 108] failed to refresh values for Multilevel Sensor CC: Failed to send t
                                  he command after 5 attempts (ZW0202)
2024-04-24T04:05:30.687Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:30.841Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-04-24T04:05:30.843Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:30.938Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:30.958Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2024-04-24T04:05:31.154Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:31.311Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:31.524Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:31.669Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:31.696Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:31.756Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:31.944Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:31.951Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.094Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.254Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.703Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.773Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.860Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.873Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.954Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:32.996Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.041Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.124Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.162Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.195Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.275Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.358Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.430Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.483Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.496Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.646Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.683Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.694Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.747Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.760Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.875Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.954Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:33.971Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.049Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.209Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.268Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.391Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.657Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.682Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.701Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:34.741Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:35.056Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:35.619Z DRIVER   Dropping message with invalid payload
2024-04-24T04:05:36.162Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:51.181Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:51.275Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:51.304Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:51.334Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:51.407Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:51.455Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:51.661Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.002Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.400Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.623Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.673Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.725Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.768Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.782Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.852Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.910Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.929Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:52.989Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.031Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.130Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.144Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.169Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.189Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.241Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.279Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.292Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.305Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.323Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.333Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.354Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.368Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.379Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.446Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.463Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.491Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.525Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.560Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.570Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.602Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:53.665Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.063Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.091Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.107Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.156Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.204Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.237Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.379Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.730Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.870Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.885Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.946Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.963Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:54.980Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:55.070Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:55.148Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:55.227Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:55.246Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:55.297Z DRIVER   Dropping message with invalid payload
2024-04-24T04:07:55.318Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:04.018Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:04.062Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:04.115Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:04.480Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:04.515Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:04.897Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.044Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.073Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.345Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.393Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.433Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.463Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.499Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.537Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.664Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.685Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.849Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.860Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.873Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.899Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.953Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:05.979Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.006Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.098Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.121Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.157Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.177Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.238Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.252Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.274Z DRIVER   Dropping message with invalid payload
2024-04-24T04:08:06.607Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:16.749Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:16.862Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:16.953Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:17.132Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:17.504Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:17.603Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:17.701Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:17.783Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:17.881Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.117Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.248Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.293Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.460Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.612Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.660Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.695Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.763Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.827Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.867Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.896Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.907Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.920Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:18.935Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.013Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.028Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.050Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.064Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.102Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.112Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.152Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.161Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.179Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.217Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.233Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.271Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.283Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.361Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.492Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.528Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.633Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:19.655Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:22.809Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:22.909Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:22.997Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:23.178Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:23.544Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:23.684Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:23.797Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:23.880Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:23.960Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.050Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.149Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.278Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.353Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.445Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.478Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.574Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.595Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.637Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.821Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.850Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.871Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.901Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.918Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.951Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.976Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:24.996Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.033Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.045Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.066Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.093Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.131Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.145Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.158Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.181Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.209Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.221Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.242Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.250Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.259Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.306Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.322Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.372Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:25.937Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.601Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.613Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.628Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.639Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.691Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.704Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.719Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.736Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.782Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.793Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:26.832Z DRIVER   Dropping message because node 240 does not exist.
2024-04-24T04:10:31.815Z DRIVER   Dropping message with invalid payload
2024-04-24T04:10:31.822Z DRIVER   Dropping message with invalid payload
What is node 127?
This may be of interest to you, without knowing which controller you are using.
Having similar problems. For the moment, relocated my HA right in the middle of my home although where it was should have been fine distance wise. Have 65 Z-wave devices on the network, a relatively new Zooz Z-wave USB stick on an USB extension cable, more horsepower, memory and disk space than HA will ever need on a dedicated host computer running HAOS. According to the logs, all the nodes RSSI was well within the reception level of the radio. Since I am at a lost right now, I relocated the HA host and rebuilding the Z-wave network (which can take a day or more). No reason for anything to fail because of signal strength since the largest distance to a node now is about 60 feet.
Went there and added my two cents along with some log fragments. Having the same problem
