I use to test my dryer a TP Link HS110 Switch Engine.
I will be notified as soon as the dryer is ready. (Pushover App)
This also works very well.
But I have a question.
My dryer turns every 10 minutes when it's ready so that the watt count is higher than 1.5 again.
Thats what i am actually checking.
For my wash mashine this works also perfect.
I get then every 10minutes again a message.
Do you have an idea how I can get the whole thing only 1x per drying process?
- alias: Dryer finished
platform: numeric_state
entity_id: sensor.dryer_watts
below: 1.5
service: notify.pushover
data_template:
title: Trockner ist fertig
message: Dryer ready
Create an input boolean.
Write an automation to turn it on when the power draw goes over say 100 watts, this way HA knows a load has started.
Add an action to your automation above to turn off the boolean when the automation triggers. Also add a condition to the automation that the boolean has to be on. That should ensure you only get a notification after the machine has been run and only once.
Thank you.
Can you help me how it could look as a code?
Actually i dont know how to build it.
Thanks.
Use a state condition for the current automation.
Thank you.
Thanks.
Thank you.
Thanks.
