Linux version same as before (no error code 29 for me). Motion detection also not working well on Linux, the motion should be on channel 0 but on Linux there is no info about that. Same script on Windows (leftside) and Linux (rightside):
Note about Linux SDK found in docs:
System Supported by SDK
Device Network SDK for Linux 32 bit:
- The version is requested to be gcc 4.1.2 or above
- The supported OS:CentOS 5.4, Redhat AS5.4,ubuntu 9.10, Fedora12 or above
Device Network SDK for Linux 64 bit:
- The supported OS: CentOS 5.4, Redhat AS5.4, SUSE10 or above
As I wrote earlier I use 64bit Ubuntu which is not officially supported (and maybe thats why I see invalid data). Can you try the script on any linux version from above?
