hm, it should work , basicly its just plain SIP, i know there is a lot of hardcoded stuff, you dont have audio, i dont have video, and i’m sure its present , because other indoor extensions can display it
i troubleshooted this, also that thread i posted on asterisk and find out that the hardware uses also fixed ports for audio and video as well
Have a look on that asterisk thread again, in first screenshot, where i traced the original trace of the hardware , notice the audio and video ports … they are on 9654 for audio and video and source was 9854 and 9856
0.70 is my outdoor, 0.72 is an indoor extension (now setup with asterisk), and 0.71 is the primary indoor where i do register asterisk on
Maybe the ports is the reason, asterisk uses different ports … like 10000 to 20000
i have tested Linphone on desktop, that SIP client is able to setup source ports as well, when i enabled here 9856 for video, i was able to see video coming in, but i never succeeded to setup fixed ports on asterisk, because it uses ranges
maybe as a test for you, just run the script on port 5061 , then on your same host where you run the script, install linphone for windows, and reister on your indoor with 10000000005 and password, and register on your indoor panel on port 5065 , then afterwards, goto network settings, and change the listening ports, for SIP : 5060 , for audio, try 9654
then make a call, and see you can answer with linphone?
