DS-KD8003 - DS-KV8113 - DS-KV8213 - DS-KV6113 - DS-KV8413 and .... integration Hikvision HikConnect Video intercom doorbell
good news :slight_smile:
it works with latest firmware as well.
thank you very much @pergola.fabio for the support!
if I can help with the HA integration development let me know
Ah, thatā€™s good news, Iā€™ll wait for next firmware to update , it should have callsatus too and event control, then i can finally ditch my esp board hooked up to the relays
is there a way to create shell_command in HA while using secret.yaml to get the password?
i have the complete isapi command as a secret
ISAPI working with 2.2.13_build210129 firmware, but restore to default settings is needed, correct?
You got this firmware from the UK download portal, right?
right
I think I had to restore default settings because my previous firmware was very old
**take into consideration that after upgrading you can no longer use 4 digit password (unfortunately)
I can use 4 digits codes, previously it was 6
@pergola.fabio you said youā€™re using 2.2.3_build201202, not 2.2.13_build210129. Or did you upgrade to 2.2.13_build210129 too?
No , running 202 , it was 6 before, now it was 4, I donā€™t see anything about back to 6 in release notes?
Strange as its not allowing me to set 4 digit only 6
Where do you set it? I use the passwords field, where you enter 16 passwords
Iā€™m talking about the public_password fields
I only have 3 passwords to set
i have there 16 passwords to set :slight_smile:
indeed, with older firmeware is was only 3 and min 6 digits
with newer firmware its 16 with min 4 digits
But I have latest firmware :scream:
strange, did you check when you did the downgrade?
would be strange that the feature is again removedā€¦
did you also update IVMS? maybe its also ivms related?
I didnā€™t update ivms I use the latest batch config tool
Iā€™ll try with latest ivms and update
according to the 2.2.13 release notes:
Updating to latest iVMS did the job!! I now see 16 passwords and I can use 4 digit again :slight_smile:thanks!
Yeah, thought so, would be strange they removed it againā€¦ Much easier to use, allthough i use the swipe system more now :slight_smile:
