But what outdoor station you have ?
he replied this earlier :
My own device is indoor panel (DS-KH8520-WTE1) and doorbell (DS-KV6103-PE1).
DS-KD8002-VM - is home own - I can’t update it.
best options are php for older non-isapi models, and isapi for newer models
not with ivms
But for olde like my laos can use IVMS-4200… maybe it is way to solution.
It’s must be empty at first start. PHP script write auth info and time last open the door.
Outdoor station is DS-KD8002-VM
Ok please write me step by step how do it… please.
like i posted before, i dont have tested it, i dont know yet
all i know you need fiddler and and capture traffic, then change those details in the php file
hey @mihalich1988 , i did a trace on my android with fiddler, but i dont see that command? also the relevant header info, where can i find ? i dont see those login urls you mention in the php
do i maybe first need to logout from the app, then start the trace, and the login when capture is enabled?
Yes, you need logout, run capture, and login and make action you need to capture.
PS You need install CA cert on phone for capture https traffic!
yeah, i did a second trace , i logged in the app, but i dont see any difference
also, on my android phone, i did install the certificate by browsing to http://ippc:8888
strange, how should it look like?
ok, i have enabled now https decryppt, also installed certificate on both desktop and android
now indeed i see https traffic, some usefull info
but, seems when the proxy is enabled, i cant use the hikconnect app if i try to login, it fails
browsing and stuff is working, only apps are not able to login
any idea? what am i missing?
seems other people have it too? how come it works with you? are you using android? or maybe older android?
https://www.telerik.com/forums/android-app-not-allowing-me-to-connect-when-‘decrypt-https-traffic’-is-enabled
edit:
seems android related, i need to run an emulator with android 5 , then it should work
hey @mihalich1988 , ok i succeed now , i am running android on emulator, android 6 , now i see https traffic in fiddler
quite nice indeed
this is the url to retrieve the last call events for example :
https://apiieu.hik-connect.com/v3/calling/listByUser?leastTime=&msgStatus=-1&pageSize=15
this is also a nice thread from another example , the user created rest sensors , also based on api of another app … i am going to rebuild it with hikconnect app
that way we have all information in HA, without the use of an .php file
and it should work for everyone, doesnt mather what firmware or model
and
Also for first generation vvideo intercom withou ISAPI and interface GUB by web port 80 ? If yes i am ready for to be a tester with model outdoor DS-KV8102-IM and indoor DS-KH8301-IM.
Yes, it’s based on hikconnect, not local
first of all setup fiddler, configure it with 2 extra options , capture HTTPS traffic AND accept remote clients AND install certificate
then on your android, i had to use an emulator, my OS version was to new, api blocked it … , setup your fiddler PC as a proxy
then you should see info like this , you need it
Please give me link to download Fiddler…
So my 6113 arrived. I can view the video streams. I can query the ISAPI interface to get the call status - tested using the following, it seems to cope with 0.2s polling.
watch -n 0.2 curl -i --digest -u admin:<password> http://<ipaddresss>/ISAPI/VideoIntercom/callStatus?format=json
Unfortunately, when I press the call button, I get a ‘Call failed’ voice alert. Any hints for how to rectify this? For info, I have just the door unit (no indoor unit) and I have simply configured the settings so far via the web browser.
Cheers,
Whytey
I think they introduced that feature to not use an indoor with a new firmware? Maybe you need to update?
wow, i started creating Rest sensors in HA to get callstatus and last calls, as seen in the HikConnect app , it works quite nice!!! thnx for get me going @mihalich1988 , there is no need for a PHP file
seems my command for a remote door open is different then yours?
https://apiieu.hik-connect.com/v3/devconfig/v1/call/Qxxx/1/remote/unlock?srcId=1&lockId=0&userType=0
maybe its based on hardware so the PUT url is different?
this sensor for example is to get the last call status (change pagesize to 15 for last 15 calls)
- platform: rest
scan_interval: 3
resource: "https://apiieu.hik-connect.com/v3/calling/listByUser?leastTime=&msgStatus=-1&pageSize=1"
headers:
customno: xxxx
appChannel: "hikvision"
Content-Type: "application/x-www-form-urlencoded"
featureCode: "xxxx"
lang: "en-US"
clientVersion: "4.14.1.0407"
appId: "HikConnect"
clientType: 55
clientNo: "google_play"
areaId: 111
netType: "WIFI"
osVersion: "5.1.1"
sessionId: xxxxx
method: GET
value_template: "Hikvision last call"
json_attributes:
- data
to get the sessionID , you need first this sensor, this wil make HA login to hikconnect
afterwards you dont need it anymore
# - platform: rest
# name: hikconnect_login
# scan_interval: 172000
# resource: "https://apiieu.hik-connect.com/v3/users/login/v2"
# headers:
# customno: xxx
# appChannel: "hikvision"
# Content-Type: "application/x-www-form-urlencoded"
# featureCode: "xxxx"
# lang: "en-US"
# clientVersion: "4.14.1.0407"
# appId: "HikConnect"
# sessionId: ""
# clientType: 55
# clientNo: "google_play"
# areaId: 111
# netType: "WIFI"
# osVersion: "5.1.1"
# method: POST
# payload: xxxxxx
# value_template: "OK"
# json_attributes:
# - loginSession
