Yes. Poll every 1 sec. Work greate.
I cannot say the exact version with which the update was carried out. However, there were no problems when upgrading from it to one of the latest that I could find. The API worked on it without any problems. After a while, I found a more recent version, but without details and release notes.
For two-way audio communication, I used an Aterisk PBX. But the sound is not that important to me, so I abandoned this solution. It also caused problems and was unstable. Web configuration for SIP is not possible, only iVMS-4200 on Windows
Hi guys,
I have kv8113-wme1 outdoor station and i want use all four alarm input, how use this inputs in HA ?
Need status on or off for this inputs.
This is a binary sensor ?
Thank you
Look at first post, all ISAPI info is available to download
I try this: curl --digest -u admin:xxx http://192.168.x.x/ISAPI/System/IO/inputs/1/status
And result is this: <?xml version="1.0" encoding="UTF-8"?>
Any ideea ?
I have an 8003, my system firmware doesnt support status on outputs/inputs, canāt help you right now, a new firmware for 8003 owners should come soon, you need help from other usersā¦
What model do you have?
where do you see it? not listed here?
From the product page itself:
https://www.hikvision.com/en/products/Video-Intercom-Products/IP-Series/Pro-Series/DS-KD8003-IME1/
ah, didnt notice
too bad, no release notes , when was it out?
Apparently on April 30th
not at home atm , did you try? let me know if callstatus now works with ISAPI ?
No, I cannot try it because hasnāt come from my supplier directly. They told me to never install firmwares downloaded from the web site, but only ones provided by them. But I feel you volunteer so much for testing it
ah , gonna asky my contact too first then
maybe best to wait untill its on portal site too
go ahead and let us know what they tell you about this version.
Will sure do
we need to wait, ISAPI not included it, this is a baseline/general firmware, the ISAPI one will be a custom version, see rls notes, nothing fancy, not worth upgradingā¦ allthough not sure what the new āDoorphone Modeā means, maybe its a new feature, that we dont need an indoor station anymore, like the other models
Hi There,
I have a DS-KV6113 (i think hardware revision A) device at my gate. Can somebody help me to figure out the latest firmware for this device because i get a little confused. Hikvision website not show any download URL and the latest firmware i find on the portal is only for the revision B. I want to integrate it to HA with the ISAPI way.
