Has anyone had any joy with creating this ASAPI integration for Home Assistant?
Yes, running smoothly for a week now
Wow thatās awesome! Need any testers?
Testing what?
It already works
Lol toucheā !
Is it available to the public yet?
What ? The ISAPI? All is in first post, for 8003, you need to load custom firmware
sorry, i assumed that you had written an integration into home assistant, via HACS or Supervisor add-on store etc.
How are you running the ISAPI commands via HA?
Callstatus , is based on a rensor
ISAPI event stream is based on python scriptā¦
The addon was for the SDK, i stopped with that , bit still the best option, but a little bit of overkill to run an extra addon just for events
Python script is also in first post
Iāll share a few findings for those who canāt use ISAPI with their doorbell:
- Linux-compiled Hikvision SDK doesnāt work on MAC, so I had to extract the libraries from iVMS-4200 app. Iām afraid Hikvision SDK for Linux wonāt work on Raspberry PI either. Havenāt tested
- My doorbell DS-KB8112-IM doesnāt report button press eventās through SDKās listening interface. Now Iām wondering if I can connect to the indoor station instead (DS-KH6210)
- Using Hik-connect appās APIs works well. SessionID is actually a JWT and is valid for 24 hours. I was only able to get the button press by specifying indoor stationās serial number, doorbellās serial number wasnāt accepted. If I canāt connect to the indoor station using the SDK, Iāll be considering to poll the API every second, and hope I donāt get banned by Hikvision or something
i used the hikconnect API, had it about 2-3 weeks active to get the callstatus, polled every 2 sec, was never blocked
indeed , linux sdk only works on centos/redhat, quite limited⦠the 32 bit version should work on ubuntu also
thats why i am using the ISAPI, i dont want to setup a seperate linux just for a doorbell, i try to run everything on HassOS ⦠creating an addon was also possible with centos, that worked for me, but quite a big overkill
How do I know whether the current door is open or closed? How to use its own door magnetic sensor?
- platform: rest
authentication: digest
username: admin
password: <password>
scan_interval: 1
resource: http://192.168.0.XXX/ISAPI/VideoIntercom/callStatus?format=json
value_template: "{{ value_json.CallStatus.status }}"
How to modify the above codeļ¼
thats for a doorbell , not for door
look first post, what device do you have? an 8003 ? then you need to update to custom firmware
Hello everybody. I am a KV8213-wme1 owner. How can I read the status of input one, as shown in the figure below?
I tried with the command
curl -i --digest -u admin:xxx http://192.168.x.x/ISAPI/Event/notification/alertStream
but I receive
<?xml version="1.0" encoding="UTF-8"?>
<ResponseStatus version="1.0" xmlns="http://www.std-cgi.com/ver10/XMLSchema">
<requestURL>/ISAPI/Event/notofication/alertStream</requestURL>
<statusCode>4</statusCode>
<statusString>Invalid Operation</statusString>
<subStatusCode>invalidOperation</subStatusCode>
<errorCode>1073741830</errorCode>
<errorMsg>invalid operation</errorMsg>
</ResponseStatus>
probably not supported on your model
try the SDK (windows only for the moment)
are you sure you entered the correct url? i see in response : /ISAPI/Event/notofication/alertStream
notofication instead of notification
Gāday Guys,
Wondering if anyone has had a play with the K1T341AM/F and ASAPI yet?
Iām struggling to find what category they fall into; Access Control or Intercom as they do both. Iāve tried a few calls from both documents with no luck, other than an āun supportedā feedback.
i have a 8003 with version 2.2.50, since the custom firmware is 2.2.45 should i be able to update? 'm using ivms but getting an error : the type of upgrade file mismatches
any way around this ?
thanks!
Hmm, never tried a downgrade
Maybe itās possible with the SDAP / batch tool, or maybe with the SDK?
I think on UK portal there are some guides to downgrade , just be careful
i read a bit about the downgrade and i was not very confident
i think i will wait for a custom firmware that can be used from 2.2.50, do you think there is a chance for that to happen ?
hmm dont think so, not soon anyway, i dont even know if the callstatus/stream ISAPI functions will be availabe in an official firmware anyway
i asked, but dont know if they are going todo it
