strange, the command looks ok, have you resetted the device after upgrade? can you actually open the door? maybe its not setup yet
that callsensor, that will give you indeed “idle”, but its always idle, also when someone pressed the doorbell, thats an issue in firmware, upgrade now to the firmware in first post, also that 2.2.45 build, that will give a good callstatus
also when you do an upgrade, make sure to factory reset the device
he wants to grab a snapshot from the camera entity, but the still image in his config is an rtsp url, that doesnt work, you need a real still image url
use motionEye, i use my synology surveillance for cameras
I haven’t reset after the upgrade as there are 3 houses on this door bell.
If I reset nobody will be able to open the door right ???
I confirm that the call sensor gives always “idle”…
I will update as soon as I fix the door open problem…
Still can’t figure out why the command is not working for me.
One more question.
Main Unit has the camera module with 3 buttons (one for each house)
How can I trigger and make automation only when my house’s button is pressed ???
(ofcourse I will update to your custom firmware but I just want to know that it is possible when do it)
the steps? well configure the door relay, make user passwords, register again swipe cards? remember, after a factory reset, the IP is back on some weird static IP , so you need ivms
make sure ivms is also updated
