normally yes, if you stay below 2.2.50, then you can do anything
but remember i’m not responsible if yiu brick anything
the custom firmware is your responsibility
No worries! At the end of the day I will buy a new KD8003
when you activate, make sure to put in the same session password as before, so your indoor devices can register again
When remove still_image from configuration i get invalid config. I want take a snapshoot from camera by automation.
i dont think its possible
install the motion eye add-on, that will give you a stream url for image
i never got isapi url’s to work for still image, i think those isapi urls are only designed for cameras
So I have update it to V2.2.45 build 210721
It did go through without problems.
Then I did a “RESET ALL” as per our conversation.
I can now confirm that the following command is working and the door opens.
curl -i --digest -u admin:1234qwer -X PUT -d '<RemoteControlDoor><cmd>open</cmd></RemoteControlDoor>' http://192.168.70.220/ISAPI/AccessControl/RemoteControl/door/1
However the callstatus sensor remains IDLE. Even though when I press the button.
I have to admit. This was a dissapointment…
Here is the code I am using
- platform: rest
name: Hikvision Doorbell Status (main entrance)
authentication: digest
username: admin
password: 1234qwer
scan_interval: 1
resource: http://192.168.70.220/ISAPI/VideoIntercom/callStatus?format=json
value_template: "{{ value_json.CallStatus.status }}"
yes, for some unkown reason the isapi url for 8003 owners must be :
http://192.168.0.70/ISAPI/VideoIntercom/callStatus?format=json&channelType=tripartitePlatform
you need to add this part : &channelType=tripartitePlatform
verry good news that you can do door open now!!
now that you are running the custom firmware, try this command too in a shell :
"curl -i --digest -u admin:xxx http://192.168.0.70/ISAPI/Event/notification/alertStream"
will give you and endless file normally, that will present you events like when someone opens the door, so you can turn on the light/spotify
I confirm that it works with this URL! Bingo!!! ![]()
Big day today! Thank you very much
no problem!! do you also see the correct number now?
Don’t need this. I can do so many other automatons with call status!
I wish there was a way to distinguish each house.
So to be able to create automation only when my house’s button is pressed …
Because no matter which nametag is pressed, call status always gives you “ring”
correct number?
you told on outdoor, there are 3 buttons for appertment, do you see what apperment is ringing in callstatus?
if I press the button, i get callstatus “ring”
I don’t know how to check if I receive something else apart “ring”
ok, but you dont know what apperment is ringing?
I know the number of my apartment.
But I think that this information is not passed on the call status …
Unless is something that I miss …
indeed, the callstatus is useless for you? because you dont know what apperment is ringing?
Exactly! I know the doorbell it rings but I don’t know which apartment’s button was pressed.
So if I make an automation that will popup a tab on tablet when callstatus is “ring” this will be for all the apartments (houses).
Unless if someone have a walk-through for this …
try the hikconnect cloud integration , maybe that sensor will tell you the number
if that doesnt work, you can also try the SDK script, thats the one i use, i dont use isapi anymore for callstatus
I am not using hikconnect. I want a lan solution not a cloud one … Besides it is slow comparing to yours …
Can try SDK but I couldn’t understand how to install it …
