DS-KD8003 - DS-KV8113 - DS-KV8213 - DS-KV6113 - DS-KV8413 and .... integration Hikvision HikConnect Video intercom doorbell
what issue do you have?
  • On indoor station DS-KH8350-WTE1, I’m using firmware 2.1.10.
    Some menu items are displayed in German instead of Italian :wink:
    Some other items where not translated correctly.
    I can share screenshots in case you are able to report.
  • On outdoor station DS-KD8003-IME1, I was using firmware 2.2.3, but I was not able to configure buttons, ‘Press Button to Call’ panel was simply empty instead of showing the list of buttons. I have screenshots for this as well.
    So I had to downgrade to firmware 2.0.8, missing the new feature of latest firmware (ONVIF support for example)
i cant create those for you, i have other hardware, i need to give SN too, so those SN’s are bound to the suppliers, i also dont have the 8350 series
i have those “press button to call” , for me it works fine, i use them to call other PBX systems
make always sure IVMS is also up to date
Are you using firmware 2.2.3? If so, where did you get it from?
also using 2.2.3 , i can define the numbers here:
This was my case with 2.2.3:
Eventually I had to downgrade to 2.0.8
i think there is also a firmware for your nametag, seems your is older
where did you get 2.2.3 from?
The UK portal?
http://www.hikvisioneurope.com/uk/portal/?dir=portal/Product%20Firmware/Hikvision/Access%20Control%20%26%20Video%20Intercom/Video%20Intercom/Second%20Generation%20Video%20Intercom/Security2.0/Modular%20Door%20Station/Main%20Module/V2.2.3_201202
yeah, i am running 2.2.3 201202 , but seems there are newer ones available
Not sure why there is a UK portal and a European portal…
I had downloaded 2.2.3 from the product page itself.
Do you plan to test the newest version 2.2.13?
not yet , i am waiting for a newer firmware
Hello everybody,
I have a problem with my video intercom. During the reboot the door contact number 2 closes causing the door to open. Is this normal behavior?
Currently it installed the version v2.1.5 build 200629
i dont have that issue, i connected NO1/COM
in fact, only port number 2 has this problem. Someone who owns the KV8113 or KV8213 can you connect a lock to contact number 2 and reboot the system?
i can confirm that this is working on DS-KV6113-WPE1
also
rtsp://user:[email protected]:554/ch1/main/av_stream
rtsp://user:[email protected]:554/Streaming/Channels/101
rtsp://user:[email protected]:554/Streaming/Channels/102
for
curl -i --digest -u admin:xxx http://192.168.x.x/ISAPI/VideoIntercom/callStatus?format=json
i get the following response
zsh: no matches found: http://192.168.1.166/ISAPI/VideoIntercom/callStatus?format=json
so its not working at the moment
thnx for feedback, gonna update TS
Never had this issue with my KV8113, both door contacts 1 and 2 are connected to NO/COM
anyone already using ISAPI for polling a doorpress event? what do you guys use for scan interval?
