jadesse
(Jason Dessenberg)
March 3, 2024, 5:03pm
1
I have a couple projects that I would like to use utilize a DS18b20 in Home Assistant through ESPHome. I tried last evening to set up my first sensor & it is not working correctly. The temperature is not being registered. First I was getting a “Scratch Pad Checksum” error. I read that ESPHome had been updated which contributed to some issues. I edited my YAML slightly & the previous error is gone but it still is not reading the temperature. I did try using a different sensor & have the same issue. Can someone please point me in the right direction?
I believe this is my board below. When I started down this path I didn’t realize there to so many versions.
esp32:
board: esp32dev
framework:
type: arduino
dallas:
In the Log below, it finds the sensor.
[10:57:16][C][logger:447]: Logger:
[10:57:16][C][logger:448]: Level: DEBUG
[10:57:16][C][logger:449]: Log Baud Rate: 115200
[10:57:16][C][logger:451]: Hardware UART: UART0
[10:57:16][C][dallas.sensor:075]: DallasComponent:
[10:57:16][C][dallas.sensor:076]: Pin: GPIO4
[10:57:16][C][dallas.sensor:077]: Update Interval: 60.0s
[10:57:16][D][dallas.sensor:082]: Found sensors:
[10:57:16][D][dallas.sensor:084]: 0xe03ce1d45814f028
[10:57:16][C][captive_portal:088]: Captive Portal:
[10:57:16][C][mdns:115]: mDNS:
[10:57:16][C][mdns:116]: Hostname: shower-wall
[10:57:16][C][ota:096]: Over-The-Air Updates:
[10:57:16][C][ota:097]: Address: shower-wall.local:3232
[10:57:16][C][ota:100]: Using Password.
[10:57:16][C][ota:103]: OTA version: 2.
[10:57:16][C][api:139]: API Server:
[10:57:16][C][api:140]: Address: shower-wall.local:6053
[10:57:16][C][api:142]: Using noise encryption: YES
Try to use internal pullup or even better external pullup resistor 2-10 k.
As well can try external component dallasng .
external_components:
- source: github://nrandell/dallasng
dallasng:
- pin:
number: GPIO04
mode:
input: True
pullup: True
- platform: dallasng
Check previous discussions regarding Dallas sensor - lot of happened and still happens.
jadesse
(Jason Dessenberg)
March 3, 2024, 7:45pm
3
I do have a 4.7K resistor installed per the ESPHome website. I’ll try editing my yaml with your suggestion & see what happens. It would not install the update until I added the addres line.
It is still not reading the temperature. Temperature failed to read scratchpad: 3
13:38:20][D][dallasng.sensor:060]: Found sensors:
[13:38:20][D][dallasng.sensor:063]: 0xe03ce1d45814f028
[13:38:20][C][dallasng.sensor:069]: Device ‘Temperature’
[13:38:20][C][dallasng.sensor:069]: Device Class: ‘temperature’
[13:38:20][C][dallasng.sensor:069]: State Class: ‘measurement’
[13:38:20][C][dallasng.sensor:069]: Unit of Measurement: ‘°C’
[13:38:20][C][dallasng.sensor:069]: Accuracy Decimals: 1
[13:38:20][C][dallasng.sensor:079]: Address: 0x1c0000031edd2a28
[13:38:20][C][dallasng.sensor:080]: Resolution: 12
[13:38:20][C][captive_portal:088]: Captive Portal:
[13:38:20][C][mdns:115]: mDNS:
[13:38:20][C][mdns:116]: Hostname: shower-wall
[13:38:20][C][ota:096]: Over-The-Air Updates:
[13:38:20][C][ota:097]: Address: shower-wall.local:3232
[13:38:20][C][ota:100]: Using Password.
[13:38:20][C][ota:103]: OTA version: 2.
[13:38:20][C][api:139]: API Server:
[13:38:20][C][api:140]: Address: shower-wall.local:6053
[13:38:20][C][api:142]: Using noise encryption: YES
[13:39:01][W][dallasng.sensor:111]: ‘Temperature’ failed to read scratchpad: 3
[13:40:01][W][dallasng.sensor:111]: ‘Temperature’ failed to read scratchpad: 3
[13:41:01][W][dallasng.sensor:111]: ‘Temperature’ failed to read scratchpad: 3
[13:42:01][W][dallasng.sensor:111]: ‘Temperature’ failed to read scratchpad: 3
[13:43:01][W][dallasng.sensor:111]: ‘Temperature’ failed to read scratchpad: 3
[13:44:01][W][dallasng.sensor:111]: ‘Temperature’ failed to read scratchpad: 3
[13:38:20][D][dallasng.sensor:060]: Found sensors:
See different sensor addresses - actually connected (found) and configured in sensor.
IMHO that is main issue.
jadesse
(Jason Dessenberg)
March 3, 2024, 10:41pm
5
Yup! I see what I did now & it is working. Thanks for pointing that out.
BTW if/when have only Dallas sensor connected You can use ’ index: 0’ instead of address specified.
