DS18B20 Sensor GPIO
Hello all
I’ve got a question, I’ve set up 1 DS18B20 temp. sensor in HASS, it worked for 2 months, “HACS 1-Wire via sysbus integration” and copy/pasting the 1 line of code on the SD card, than the integration would read the GPIO and create a file in /sys/bus/w1/devices (I could see the file going via SSH Terminal, now it isn’t there anymore) and I could set it on my dashboard, however, yesterday it gave an error that the entity is not available anymore (my guess is since the last core update, is that possible? I do not look at the sensor everyday, so could be a couple of days) I’ve tried deleting the integration, re-installing, installing an older version → nothing…
Does anyone have the same problem? Or have a solution? My guess is that it is a software problem OR my sensor has died on me OR the 1 line code on my SD has disappeared (maybe because of the update)?
Thanks!
Always check the breaking changes section of each update. In 2022.2 GPIO was deprecated. In 2022.6 1-wire was deprecated.
I know, but HACS added it as an integration, I’ve only setup the 1-wire like 2 months ago (after it stopped working on regular HASS), I should’ve added it, I had it working via HACS
It’s solved, it popped back up without doing anything…
@KLServer
Please can you share your setup for this sensor
I need it for my raspberry pi too
