Ds18b20 Wrong resistor ? Something else?
Bought these resistors :
No device found
# Substitution Variables
substitutions:
  device_internal_name: test
  device_friendly_name: Test
  device_ip_address: 10.0.0.83
# Board Configuration
esphome:
  friendly_name: ${device_friendly_name}
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  - platform: esphome
safe_mode:
# WiFi
wifi:
  networks:
  - ssid: "dd-wrt"
    password: "xx"
  - ssid: "SNOW"
    password: "xx"
  power_save_mode: none
#  output_power: 8.5dB
  # Enable fallback hotspot in case wifi connection fails
  ap:
    ssid: ${device_friendly_name} Fallback Hotspot
    password: "xx"
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: ${device_ip_address}
    # Set this to the IP address of the router. Often ends with .1
    gateway: 10.0.0.1
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: 255.255.255.0
    dns1: 1.1.1.1
    dns2: 8.8.8.8
captive_portal:
debug:
  update_interval: 1min # How often to check the memory.
button:
- platform: safe_mode
  name: "Safe Mode Boot ${device_friendly_name}"
  entity_category: diagnostic
- platform: restart
  name: "Restart ${device_friendly_name}"
binary_sensor:
  - platform: status
    name: Status ${device_friendly_name}
# Text Sensors.
text_sensor:
  - platform: wifi_info
    ip_address:
      name: IP Address ${device_friendly_name}
      icon: mdi:ip-network
    ssid:
      name: Connected SSID ${device_friendly_name}
    mac_address:
      name: Mac Wifi Address ${device_friendly_name}
  - platform: debug
    reset_reason:
      name: Reset Reason ${device_friendly_name}
      icon: "mdi:information-outline"
  # Custom Text sensors
    name: Uptime Human Readable ${device_friendly_name}
    icon: mdi:clock-start
  # Creates a sensor in Home Assistant with the free memory value.
  - platform: debug
    free:
      name: Heap Free ${device_friendly_name}
      unit_of_measurement: "B" # B for Bytes
      icon: "mdi:memory"
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: WiFi Signal dB ${device_friendly_name}
    update_interval: 60s
    entity_category: "diagnostic"
  - platform: copy # Reports the WiFi signal strength in %
    source_id: wifi_signal_db
    name: WiFi Signal Percent ${device_friendly_name}
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "%"
    device_class: ""
  # Uptime
  - platform: uptime
    name: Uptime Sensor ${device_friendly_name}
    update_interval: 100s
#    internal: true
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(${device_internal_name}_uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
  - platform: dallas_temp
#    address: 0x9900000059ab5828
    name: ${device_friendly_name} Temperature
interval:
  - interval: 60s
    then:
      - logger.log: Heartbeat - ${device_friendly_name} is alive!
# Example configuration entry
one_wire:
  - platform: gpio
    pin: GPIO4
Log :
[14:00:44][C][safe_mode:084]: Unsuccessful boot attempts: 0
[14:00:44][I][app:073]: Running through setup()
[14:00:44][C][component:163]: Setup logger took 0ms
[14:00:44][C][component:163]: Setup gpio.one_wire took 2ms
[14:00:44][C][component:163]: Setup preferences took 0ms
[14:00:44][C][component:163]: Setup template.text_sensor took 0ms
[14:00:44][C][component:163]: Setup uptime.sensor took 0ms
[14:00:44][C][component:163]: Setup safe_mode.button took 0ms
[14:00:44][C][component:163]: Setup restart.button took 0ms
[14:00:44][D][binary_sensor:039]: 'Status Test': New state is OFF
[14:00:44][C][component:163]: Setup status.binary_sensor took 6ms
[14:00:44][D][text_sensor:069]: 'Mac Wifi Address Test': Sending state 'A4:CF:12:BF:4F:E8'
[14:00:44][C][component:163]: Setup wifi_info.text_sensor took 8ms
[14:00:44][C][component:163]: Setup copy.sensor took 0ms
[14:00:44][E][one_wire:026]: No devices, can't auto-select address
[14:00:44][C][component:163]: Setup dallas_temp.sensor took 6ms
[14:00:44][C][component:163]: Setup interval took 1ms
[14:00:44][C][component:163]: Setup web_server_base took 0ms
[14:00:44][C][component:163]: Setup captive_portal took 0ms
[14:00:44][C][wifi:060]: Starting
[14:00:44][C][wifi:060]:  Local MAC: A4:CF:12:BF:4F:E8
[14:00:44][D][wifi:507]: Starting scan
[14:00:44][C][component:163]: Setup wifi took 22ms
[14:00:44][W][component:296]: wifi set Warning flag: scanning for networks
[14:00:45][D][main:201]: Heartbeat - Test is alive!
[14:00:45][D][text_sensor:069]: 'Uptime Human Readable Test': Sending state '1s'
[14:00:45][D][sensor:131]: 'Uptime Sensor Test': Sending state 1.12100 s with 0 decimals of accuracy
[14:00:50][D][wifi:576]: Found networks:
[14:00:50][I][wifi:599]: - 'dd-wrt' (1C:BF:CE:80:D8:54) [redacted]β–‚β–„β–†β–ˆ
[14:00:50][D][wifi:601]:     Channel: 6
[14:00:50][D][wifi:601]:    RSSI: -62 dB
[14:00:50][I][wifi:599]: - 'SNOW' (10:FE:ED:AF:44:7A) [redacted]β–‚β–„β–†β–ˆ
[14:00:50][D][wifi:601]:     Channel: 1
[14:00:50][D][wifi:601]:    RSSI: -65 dB
[14:00:50][I][wifi:599]: - 'SNOW' (3C:37:12:CE:A0:FE) [redacted]β–‚β–„β–†β–ˆ
[14:00:50][D][wifi:601]:    RSSI: -70 dB
[14:00:50][I][wifi:599]: - 'dd-wrt' (1C:3B:F3:C7:26:8C) [redacted]β–‚β–„β–†β–ˆ
[14:00:50][D][wifi:601]:     Channel: 8
[14:00:50][D][wifi:601]:    RSSI: -81 dB
[14:00:50][D][wifi:606]: - ''[redacted] (00:14:C1:38:CD:CC) [redacted]β–‚β–„β–†β–ˆ
[14:00:50][D][wifi:606]: - 'Kotje'[redacted] (9C:53:22:50:35:90) [redacted]β–‚β–„β–†β–ˆ
[14:00:50][I][wifi:329]: Connecting to 'dd-wrt'
[14:00:52][I][wifi:675]: Connected
[14:00:52][C][wifi:444]:   Local MAC: A4:CF:12:BF:4F:E8
[14:00:52][C][wifi:449]:   SSID: 'dd-wrt'[redacted]
[14:00:52][C][wifi:452]:   IP Address: 10.0.0.83
[14:00:52][C][wifi:456]:   BSSID: 1C:BF:CE:80:D8:54[redacted]
[14:00:52][C][wifi:456]:  Hostname: 'test'
[14:00:52][C][wifi:456]:  Signal strength: -60 dB β–‚β–„β–†β–ˆ
[14:00:52][C][wifi:467]:   Channel: 6
[14:00:52][C][wifi:467]:  Subnet: 255.255.255.0
[14:00:52][C][wifi:467]:  Gateway: 10.0.0.1
[14:00:52][C][wifi:467]:  DNS1: 1.1.1.1
[14:00:52][C][wifi:467]:  DNS2: 8.8.8.8
[14:00:52][D][wifi:689]: Disabling AP
[14:00:52][C][component:163]: Setup esphome.ota took 0ms
[14:00:52][C][component:163]: Setup safe_mode took 0ms
[14:00:52][C][component:163]: Setup web_server.ota took 0ms
[14:00:52][W][component:287]: api set Warning flag: unspecified
[14:00:52][C][component:163]: Setup api took 6ms
[14:00:52][C][component:163]: Setup wifi_info.text_sensor took 0ms
[14:00:52][C][component:163]: Setup wifi_signal.sensor took 0ms
[14:00:52][C][component:163]: Setup mdns took 2ms
[14:00:52][C][component:163]: Setup debug took 0ms
[14:00:52][I][app:120]: setup() finished successfully!
[14:00:52][D][text_sensor:069]: 'Connected SSID Test': Sending state 'dd-wrt'
[14:00:52][W][component:326]: wifi cleared Warning flag
[14:00:52][I][app:185]: ESPHome version 2025.9.1 compiled on Sep 29 2025, 13:11:50
[14:00:52][C][wifi:661]: WiFi:
[14:00:52][C][wifi:456]:  Signal strength: -61 dB β–‚β–„β–†β–ˆ
[14:00:52][C][logger:273]: Logger:
[14:00:52][C][logger:273]:  Max Level: DEBUG
[14:00:52][C][logger:273]:  Initial Level: DEBUG
[14:00:52][C][logger:279]:   Log Baud Rate: 115200
[14:00:52][C][logger:279]:  Hardware UART: UART0
[14:00:52][C][gpio.one_wire:021]: GPIO 1-wire bus:
[14:00:52][C][gpio.one_wire:022]:   Pin: GPIO4
[14:00:52][W][gpio.one_wire:082]:   Found no devices!
[14:00:52][C][template.text_sensor:020]: Template Sensor 'Uptime Human Readable Test'
[14:00:52][C][template.text_sensor:020]:   Icon: 'mdi:clock-start'
[14:00:52][C][uptime.sensor:015]: Uptime Sensor 'Uptime Sensor Test'
[14:00:52][C][uptime.sensor:015]:  State Class: 'total_increasing'
[14:00:52][C][uptime.sensor:015]:  Unit of Measurement: 's'
[14:00:52][C][uptime.sensor:015]:  Accuracy Decimals: 0
[14:00:52][C][uptime.sensor:025]:   Device Class: 'duration'
[14:00:52][C][uptime.sensor:029]:   Icon: 'mdi:timer-outline'
[14:00:52][C][uptime.sensor:033]:   Type: Seconds
[14:00:52][C][safe_mode.button:015]: Safe Mode Button 'Safe Mode Boot Test'
[14:00:52][C][safe_mode.button:018]:   Icon: 'mdi:restart-alert'
[14:00:52][C][restart.button:015]: Restart Button 'Restart Test'
[14:00:52][C][restart.button:018]:   Icon: 'mdi:restart'
[14:00:52][C][status:016]: Status Binary Sensor 'Status Test'
[14:00:52][C][status:019]:   Device Class: 'connectivity'
[14:00:52][C][wifi_info:014]: MAC Address 'Mac Wifi Address Test'
[14:00:52][C][copy.sensor:015]: Copy Sensor 'WiFi Signal Percent Test'
[14:00:52][C][copy.sensor:015]:  State Class: 'measurement'
[14:00:52][C][copy.sensor:015]:  Unit of Measurement: '%'
[14:00:52][C][copy.sensor:015]:  Accuracy Decimals: 0
[14:00:52][C][dallas.temp.sensor:029]: Dallas Temperature Sensor:
[14:00:52][W][dallas.temp.sensor:031]:   Unable to select an address
[14:00:52][C][captive_portal:122]: Captive Portal:
[14:00:52][C][esphome.ota:075]: Over-The-Air updates:
[14:00:52][C][esphome.ota:075]:  Address: 10.0.0.83:8266
[14:00:52][C][esphome.ota:075]:  Version: 2
[14:00:52][C][safe_mode:018]: Safe Mode:
[14:00:52][C][safe_mode:018]:  Successful after: 60s
[14:00:52][C][safe_mode:018]:  Invoke after: 10 attempts
[14:00:52][C][safe_mode:018]:  Duration: 300s
[14:00:52][C][web_server.ota:235]: Web Server OTA
[14:00:52][C][api:205]: Server:
[14:00:52][C][api:205]:  Address: 10.0.0.83:6053
[14:00:52][C][api:215]:   Noise encryption: NO
[14:00:52][C][wifi_info:012]: SSID 'Connected SSID Test'
[14:00:52][C][wifi_info:010]: IP Address 'IP Address Test'
[14:00:52][C][wifi_info:010]:   Icon: 'mdi:ip-network'
[14:00:52][C][wifi_signal.sensor:015]: WiFi Signal 'WiFi Signal dB Test'
[14:00:52][C][wifi_signal.sensor:015]:  State Class: 'measurement'
[14:00:52][C][wifi_signal.sensor:015]:  Unit of Measurement: 'dBm'
[14:00:52][C][wifi_signal.sensor:015]:  Accuracy Decimals: 0
[14:00:52][C][wifi_signal.sensor:025]:   Device Class: 'signal_strength'
[14:00:52][C][mdns:213]: mDNS:
[14:00:52][C][mdns:213]:  Hostname: test
[14:00:52][C][debug:018]: Debug component:
[14:00:52][C][debug:015]:   Free space on heap 'Heap Free Test'
[14:00:52][C][debug:015]:    State Class: ''
[14:00:52][C][debug:015]:    Unit of Measurement: 'B'
[14:00:52][C][debug:015]:    Accuracy Decimals: 0
[14:00:52][C][debug:029]:     Icon: 'mdi:memory'
[14:00:52][D][debug:033]: ESPHome version 2025.9.1
[14:00:52][D][debug:037]: Free Heap Size: 36960 bytes
[14:00:52][D][debug:041]: Flash Chip: Size=1024kB Speed=40MHz Mode=DOUT
[14:00:52][D][debug:050]: Chip ID: 0x00BF4FE8
[14:00:52][D][debug:051]: SDK Version: 2.2.2-dev(38a443e)
[14:00:52][D][debug:052]: Core Version: 3.1.2
[14:00:52][D][debug:053]: Boot Version=31 Mode=1
[14:00:52][D][debug:054]: CPU Frequency: 80
[14:00:52][D][debug:055]: Flash Chip ID=0x001640EF
[14:00:52][D][debug:056]: Reset Reason: External System
[14:00:52][D][debug:057]: Reset Info: External System
[14:00:52][D][text_sensor:069]: 'Reset Reason Test': Sending state 'External System'
[14:00:52][D][text_sensor:069]: 'IP Address Test': Sending state '10.0.0.83'
[14:00:53][D][sensor:131]: 'WiFi Signal dB Test': Sending state -62.00000 dBm with 0 decimals of accuracy
[14:00:53][D][sensor:131]: 'WiFi Signal Percent Test': Sending state 76.00000 % with 0 decimals of accuracy
[14:00:56][D][sensor:131]: 'Heap Free Test': Sending state 37224.00000 B with 0 decimals of accuracy
[14:01:44][I][safe_mode:042]: Boot seems successful; resetting boot loop counter
[14:01:45][D][main:201]: Heartbeat - Test is alive!
Terminal disconnected: NetworkError: The device has been lost.
Wiring:
You bought 4.7R, way too low for pullup. You need 4.7K instead.
Also, you should use 3.3V pin instead of 5V, now your gpio pin is pulled up to 5V.
Thanks. I guessed already.
You might consider assortment kit, you can find them <$10 on amazon.
Second time in a week for this DS18B20 4R7 issue: ESP8266 - temperature sensor troubleshooting - #18 by tom_l
Also:
  1. Buy 1% metal film assortments from Aliexpress.
  2. Find they are factory seconds, just outside tolerance.
  3. Send photo proof for refund using a Fluke multimeter.
  4. Free (better than 5%) resistors!
So first order Fluke from amazon and return it after photo (i’m poor guy) :sweat_smile:
No that would be dishonest.
I rarely return anything there, but I see that available return reasons have β€œNo longer needed”. :innocent:
Do that too many times and they will likely cut you off.
Of course and I was joking. My return ratio is ~1% though, they treat me nicely…
