DS218play - problem with install
Hello. I installed HA with from community repo. It installed very well, but I cannot start it. I have DSM 6.2.4, Python 3.8, but the HA service won’t start. Any suggestions? Is there any way to install HA on my NAS?
As mentioned here it is no longer working or supported: Home Assistant Supervised (previously known as Hass.io) on Synology DSM as native package (not supported or working atm)
Thank you for your quick reply! However, I have a question if I will be able to do this on this synology model using Docker (ARM processor).
You can run HA-Core in Docker https://www.home-assistant.io/installation/alternative#synology-nas
Do note that this (Container mode) will not give you access to addons: https://www.home-assistant.io/installation/#compare-installation-methods
So I should buy something else if I want to use add-ons (Zigbee2mqtt Edge and Zigbee2mqtt Edge (for Xiaomi Gateway 3 integration). Thank you for your help!
It is possible to run Zigbee2MQTT in a Docker container using the official Zigbee2MQTT Docker image.
Ref: | Zigbee2MQTT
How are your google skills :stuck_out_tongue:?
