Have you had issues with the bypass switches if updating past 2022.2? I seem to lose them if upgrading.
Yeah, they were removed. People where the alarm is configured to require a pin when bypassing a zone had machine issues.
Interesting. I like to leave the garage door cracked for the dogs and bypass that zone when setting the alarm… Any thoughts on a workaround for HA? I suppose I could still bypass manually with the envisalink app, but its less convenient…
You can use the send command function to bypass a zone with 1<zone_nr># I think.
Problem is, there is no visibility in HA if a zone is bypassed.
So for now, I am still on HA 2022.2.5 which is the latest version with the bypass switches still enabled.
On the side, I am working on something else as a work-around, but it is going slow.
wonder why this integration isn’t in GUI where there is so much movement to gui for so many things…
