Hello, I get an unexpected error when I try to configure my Synology 1621+ with DSM 7.1 in HA. It seems according to the log file a part is read out but then an “Error Code 1052” comes up. Does anyone have any idea what is going wrong?
2022-10-11 11:53:21.917 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] API: SYNO.API.Auth
2022-10-11 11:53:21.918 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Request Method: GET
2022-10-11 11:53:22.353 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Request url: http://192.168.1.3:5000/webapi/entry.cgi?account=********&passwd=********&enable_device_token=yes&device_name=46db5e2f62c9&api=SYNO.API.Auth&version=7&method=login
2022-10-11 11:53:22.353 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Response status_code: 200
2022-10-11 11:53:22.354 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Response headers: {'Server': 'nginx', 'Date': 'Tue, 11 Oct 2022 09:53:22 GMT', 'Content-Type': 'application/json; charset="UTF-8"', 'Transfer-Encoding': 'chunked', 'Connection': 'keep-alive', 'Keep-Alive': 'timeout=20', 'Vary': 'Accept-Encoding', 'P3P': 'CP="IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT"', 'X-Content-Type-Options': 'nosniff, nosniff', 'X-XSS-Protection': '1; mode=block, 1; mode=block', 'Set-Cookie': 'id=Q_HShahlqGy9KJZb4_bC_9NDi9yE199FkCV3hKm3o34-C6zMbhSJY4fYlTTedxszjEfpMP7RHXM_NDBj1jARAo;expires=Tue, 18-Oct-2022 09:53:22 GMT;path=/;HttpOnly, did=NBqyO4xGP9LNEq-UcVnwM6QuxpvHU9lgyyeh-f8Oc-i1Vv7t3RmtJj6ouPAmTHK-3gl8J4I85YeDlXCJgXdcTQ;expires=Wed, 11-Oct-2023 09:53:22 GMT;path=/;HttpOnly', 'Cache-Control': 'max-age=0, no-cache, no-store, must-revalidate', 'Pragma': 'no-cache', 'Expires': '0', 'Content-Encoding': 'gzip'}
2022-10-11 11:53:22.354 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Successful returned data
2022-10-11 11:53:22.354 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] RESPONSE: {'data': {'account': 'homeassistant-synology', 'device_id': 'NBqyO4xGP9LNEq-UcVnwM6QuxpvHU9lgyyeh-f8Oc-i1Vv7t3RmtJj6ouPAmTHK-3gl8J4I85YeDlXCJgXdcTQ', 'ik_message': '', 'is_portal_port': False, 'sid': 'Q_HShahlqGy9KJZb4_bC_9NDi9yE199FkCV3hKm3o34-C6zMbhSJY4fYlTTedxszjEfpMP7RHXM_NDBj1jARAo', 'synotoken': '--------'}, 'success': True}
2022-10-11 11:53:22.354 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Authentication successful, token: Q_HShahlqGy9KJZb4_bC_9NDi9yE199FkCV3hKm3o34-C6zMbhSJY4fYlTTedxszjEfpMP7RHXM_NDBj1jARAo
2022-10-11 11:53:22.354 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] API: SYNO.DSM.Info
2022-10-11 11:53:22.354 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Request Method: GET
2022-10-11 11:53:22.508 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Request url: http://192.168.1.3:5000/webapi/entry.cgi?api=SYNO.DSM.Info&version=2&method=getinfo&_sid=********&SynoToken=********
2022-10-11 11:53:22.508 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Response status_code: 200
2022-10-11 11:53:22.508 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Response headers: {'Server': 'nginx', 'Date': 'Tue, 11 Oct 2022 09:53:22 GMT', 'Content-Type': 'application/json; charset="UTF-8"', 'Transfer-Encoding': 'chunked', 'Connection': 'keep-alive', 'Keep-Alive': 'timeout=20', 'Vary': 'Accept-Encoding', 'Set-Cookie': 'id=Q_HShahlqGy9KJZb4_bC_9NDi9yE199FkCV3hKm3o34-C6zMbhSJY4fYlTTedxszjEfpMP7RHXM_NDBj1jARAo;expires=Tue, 18-Oct-2022 09:53:22 GMT;path=/;HttpOnly', 'X-Content-Type-Options': 'nosniff', 'X-XSS-Protection': '1; mode=block', 'Cache-Control': 'max-age=0, no-cache, no-store, must-revalidate', 'Pragma': 'no-cache', 'Expires': '0', 'Content-Encoding': 'gzip'}
2022-10-11 11:53:22.508 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Successful returned data
2022-10-11 11:53:22.508 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] RESPONSE: {'data': {'codepage': 'ger', 'model': 'DS1621+', 'ram': 32768, 'serial': '2080S7RT2A4KC', 'temperature': 63, 'temperature_warn': False, 'time': 'Tue Oct 11 11:53:22 2022', 'uptime': 5348354, 'version': '42661', 'version_string': 'DSM 7.1-42661 Update 4'}, 'success': True}
2022-10-11 11:53:22.508 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] API: SYNO.Core.System.Utilization
2022-10-11 11:53:22.508 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Request Method: GET
2022-10-11 11:53:44.464 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Successful returned data
2022-10-11 11:53:44.464 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] RESPONSE: {'error': {'code': 1052, 'errors': {'err_line': 191, 'err_msg': 'Transmition get failed Result.'}}, 'success': False}
2022-10-11 11:53:44.465 DEBUG (SyncWorker_5) [synology_dsm.synology_dsm] Session error: 1052
2022-10-11 11:53:44.466 ERROR (MainThread) [homeassistant.components.synology_dsm.config_flow] {'api': 'SYNO.Core.System.Utilization', 'code': 1052, 'reason': 'Unknown', 'details': {'err_line': 191, 'err_msg': 'Transmition get failed Result.'}}
Greetings
