Hey all,
I used to read my smart meter DSMR with a usb-serial cable without any issue. However after some of the recent upgrades I have some issues in my log file. The readings still work and seem to be up to date, however it seems to be in delay due to the errors presumably.
The default settings have been used by me for quite some time.
Running raspberry 3B, hassio 73.1
- platform: dsmr
Wed Jul 11 2018 11:11:24 GMT+0200 (CEST)
Error doing job: Exception in callback <bound method SerialTransport._read_ready of SerialTransport(<uvloop.Loop running=True closed=False debug=False>, <dsmr_parser.clients.protocol.DSMRProtocol object at 0x7374e4d0>, Serial<id=0x7349dfd0, open=True>(port='/dev/ttyUSB0', baudrate=9600, bytesize=7, parity='E', stopbits=1, timeout=0, xonxoff=0, rtscts=0, dsrdtr=False))>
File "uvloop/cbhandles.pyx", line 62, in uvloop.loop.Handle._run
File "/usr/lib/python3.6/site-packages/serial_asyncio/__init__.py", line 106, in _read_ready
self._protocol.data_received(data)
File "/usr/lib/python3.6/site-packages/dsmr_parser/clients/protocol.py", line 88, in data_received
self.handle_telegram(telegram)
File "/usr/lib/python3.6/site-packages/dsmr_parser/clients/protocol.py", line 103, in handle_telegram
parsed_telegram = self.telegram_parser.parse(telegram)
File "/usr/lib/python3.6/site-packages/dsmr_parser/parsers.py", line 57, in parse
telegram[signature] = parser.parse(match.group(0))
File "/usr/lib/python3.6/site-packages/dsmr_parser/parsers.py", line 136, in parse
return MBusObject(self._parse(line))
File "/usr/lib/python3.6/site-packages/dsmr_parser/parsers.py", line 115, in _parse
for i, value in enumerate(values)]
File "/usr/lib/python3.6/site-packages/dsmr_parser/parsers.py", line 115, in <listcomp>
File "/usr/lib/python3.6/site-packages/dsmr_parser/parsers.py", line 212, in parse
value = self.coerce_type(value) if value is not None else value
ValueError: invalid literal for int() with base 10: '2C
I have been searching the forum for a bit but could not find a similar issue. Thanks heaps for any suggestions, Tim
