DSMR installation problems
I am trying to get the DSMR working. This is in my configuration:
- platform: dsmr
  port: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AC2F1FPH-if00-port0
But all sensors return “Unknown”. I also tried removing the port, as it takes /dev/ttyUSB0 as default which it is currently on, but I want to use the serial by id.
This is the cable I am using: https://www.sossolutions.nl/slimme-meter-kabel
What can I change to make it work?
Did you read this?
