I want my HA ( core-2021.1.5 on Home Assistant OS 5.10 , on Raspberry Pi4B 2GB) to display consumption and production data
from my Belgian ‘slimme meter’ SAGEMCOM T211 using a P1 cable.
I have no experience in yaml files but following the docs i installed the DSMR integration by editing my /config/configuration.yaml:
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Example configuration.yaml entry for USB/serial connected Smartmeter
- platform: dsmr
port: /dev/ttyUSB1
dsmr_version: 5B
Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
No entities are created, nothing visible in the main command screen.
Tried with different port numbers, without any difference
Tried with dsmr_version : 5 or 5B (for Belgian, like it should be i think)
Tried adding a set of entities like suggested in the docs:
group:
meter_readings:
entities:
- sensor.energy_consumption_tarif_1
- sensor.energy_consumption_tarif_2
- sensor.energy_production_tarif_1
- sensor.energy_production_tarif_2
This addition results in some effect: includes in the main command screen a block “meter readings” with the 4 entities, saying:
“entiteit niet beschikbaar”
Log doesn’t show any failing component…
Installed add-ons :
file editor and Motioneye
Installed integrations through GUI:
DENON, KODI, meteorologisk institutt, Mobile app, Philips Hue, Raspberry pi power supply checker, Speedtest.net, Synology DSM, Tado, UPnP
Any other suggestions/experiences are appreciated that could be useful to end this process of trying and retrying ?!?!
THX
Kris
