DSMR Reader Add-on for Home Assistant
I updated the DSMR Reader to version 1.1.1 yesterday, and now there’s a problem. I’m getting these errors in the log:
22-04-04 09:20:58 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on 0826754b/aarch64-addon-dsmr_reader with version 1.1.0
22-04-04 09:21:58 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with 0826754b_dsmr_reader!
22-04-04 09:21:58 WARNING (MainThread) [supervisor.addons.options] Option 'DATALOGGER_MODE' does not exist in the schema for DSMR Reader (0826754b_dsmr_reader)
22-04-04 09:21:58 WARNING (MainThread) [supervisor.addons.options] Option 'DATALOGGER_SERIAL_PORT' does not exist in the schema for DSMR Reader (0826754b_dsmr_reader)
22-04-04 09:21:58 WARNING (MainThread) [supervisor.addons.options] Option 'DATALOGGER_INPUT_METHOD' does not exist in the schema for DSMR Reader (0826754b_dsmr_reader)
22-04-04 09:21:58 WARNING (MainThread) [supervisor.addons.options] Option 'DATALOGGER_SERIAL_BAUDRATE' does not exist in the schema for DSMR Reader (0826754b_dsmr_reader)
22-04-04 09:21:58 WARNING (MainThread) [supervisor.addons.options] Option 'DATALOGGER_NETWORK_HOST' does not exist in the schema for DSMR Reader (0826754b_dsmr_reader)
22-04-04 09:21:58 WARNING (MainThread) [supervisor.addons.options] Option 'DATALOGGER_NETWORK_PORT' does not exist in the schema for DSMR Reader (0826754b_dsmr_reader)
22-04-04 09:21:58 WARNING (MainThread) [supervisor.addons.options] Option 'DATALOGGER_SLEEP' does not exist in the schema for DSMR Reader (0826754b_dsmr_reader)
I have reverted back to version 1.1.0, but these errors are still showing up, and the web page simply shows “192.168.178.148 refused to connect” (the URL is 192.168.178.148:8123/dmsr).
Any suggestions? Thanks.
Go to the addon “Configuration” tab and next to “Options” choose “Reset to defaults” (Not the one below “Network”) and apply your settings again.
I’ve done that, and tried both restarting HA, and then rebooting the Host, but the errors persist I’m afraid…
Hi sanderdw
I have the same errors. When I choose “Reset to defaults” I want to save these settings, but “save” remains greyed out. So I assume that I’m using the default settings. (nothing visually changes when clicking reset). The errors remain.
Yves
Can you try to uninstall the addon and reinstall it again?
Which hardware are you using?
Just flip a setting, save, flip it back and save again?
Will do. I’m using a RPi4 and a USB SSD to hold HA and data.
I went to Uninstall the add-on, and noticed a “Rebuild” button. Should I try that first?
No, uninstall and reinstall :nerd_face:
Done that, but still the same errors. I notice in the DSMR log that it can’t connect to the database?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-set-hassio-vars: executing... [ INFO ] Home Assistant Add-on release: 1.1.1 [ INFO ] Home Assistant Add-on: This addon is the latest version [ INFO ] Configuring Home Assistant Addon options [cont-init.d] 01-set-hassio-vars: exited 0. [cont-init.d] 10-adduser: executing... ------------------------- User UID: 0 User GID: 0 ------------------------- [cont-init.d] 10-adduser: exited 0. [cont-init.d] 20-set-app-defaults: executing... [ INFO ] DSMR Reader release: 5.1.0 [ INFO ] DSMR Reader Docker release: 2022.04.01 [ INFO ] Ensure permissions... [ INFO ] Setting architecture requirements... [ INFO ] ARM Architecture [ INFO ] Enabling IFrame... [ INFO ] Fixing /dev/ttyUSB* security... chmod: changing permissions of '/dev/ttyUSB0': Read-only file system [ INFO ] Verifying if the DSMR web credential variables have been set... [ INFO ] Verifying database connectivity to host: 77b2833f-timescaledb with port: 5432... Testing database connectivity: 1 second(s) of 30 seconds... Testing database connectivity: 2 second(s) of 30 seconds... Testing database connectivity: 3 second(s) of 30 seconds... Testing database connectivity: 4 second(s) of 30 seconds... Testing database connectivity: 5 second(s) of 30 seconds... Testing database connectivity: 6 second(s) of 30 seconds... Testing database connectivity: 7 second(s) of 30 seconds... Testing database connectivity: 8 second(s) of 30 seconds... Testing database connectivity: 9 second(s) of 30 seconds... Testing database connectivity: 10 second(s) of 30 seconds... Testing database connectivity: 11 second(s) of 30 seconds... Testing database connectivity: 12 second(s) of 30 seconds... Testing database connectivity: 13 second(s) of 30 seconds... Testing database connectivity: 14 second(s) of 30 seconds... Testing database connectivity: 15 second(s) of 30 seconds... Testing database connectivity: 16 second(s) of 30 seconds... Testing database connectivity: 17 second(s) of 30 seconds... Testing database connectivity: 18 second(s) of 30 seconds... Testing database connectivity: 19 second(s) of 30 seconds... Testing database connectivity: 20 second(s) of 30 seconds... Testing database connectivity: 21 second(s) of 30 seconds... Testing database connectivity: 22 second(s) of 30 seconds... Testing database connectivity: 23 second(s) of 30 seconds... Testing database connectivity: 24 second(s) of 30 seconds... Testing database connectivity: 25 second(s) of 30 seconds... Testing database connectivity: 26 second(s) of 30 seconds... Testing database connectivity: 27 second(s) of 30 seconds... Testing database connectivity: 28 second(s) of 30 seconds... Testing database connectivity: 29 second(s) of 30 seconds... Testing database connectivity: 30 second(s) of 30 seconds... [ FAIL ] Database connectivity couldn't be verified! Please verify your settings. Exiting... [cont-init.d] 20-set-app-defaults: exited 1. [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] waiting for services. [s6-finish] sending all processes the TERM signal.
Correction, the Supervisor log now just shows:
22-04-04 11:33:56 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on 0826754b/aarch64-addon-dsmr_reader with version 1.1.1
22-04-04 11:37:18 ERROR (SyncWorker_7) [supervisor.docker.interface] Container addon_0826754b_dsmr_reader is not running
OK, something seems to be wrong with the Timescale DB…
[11:40:25] NOTICE: Upgrading databases..
Performing Consistency Checks
Checking cluster versions                                   ok
Checking database user is the install user                  ok
Checking database connection settings                       ok
Checking for prepared transactions                          ok
Checking for system-defined composite types in user tables  ok
Checking for reg* data types in user tables                 ok
Checking for contrib/isn with bigint-passing mismatch       ok
Checking for user-defined encoding conversions              ok
Checking for user-defined postfix operators                 ok
Creating dump of global objects                             ok
Creating dump of database schemas
  dsmrreader
  homeassistant
  postgres
  template1
                                                            ok
Checking for presence of required libraries                 fatal
Your installation references loadable libraries that are missing from the
new installation.  You can add these libraries to the new installation,
or remove the functions using them from the old installation.  A list of
problem libraries is in the file:
    loadable_libraries.txt
Failure, exiting
[11:40:37] ERROR: PostgreSQL could not upgrade! Please inspect any errors in the lines above!
[11:40:37] ERROR: Upgrade was not succesfull.
[cont-init.d] init.sh: exited 1.
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[s6-finish] sending all processes the KILL signal and exiting.
That’s indeed an other problem, look at my comment earlyer: DSMR Reader Add-on for Home Assistant - #208 by sanderdw
Yup. reinstalled version 1.1.6 from a backup and now running with DSMR 1.1.0. I’ll wait until the issues have been sorted before upgrading. Thanks for your help.
You should be able to safely upgrade to the DSMR Addon 1.1.1 though.
The problem with upgrading the Timescale db is that there’s an entry for dsmrreader missing from the timescal_enabled section of the configuration file…
I have the exact same issue.
Reverting back a version for timescale db addon, fixed it for me…
Have a look at the @gcoupe suggestion and check if the upgrade will complete. Otherwise i would suggest to go to that addon specific thread: Home Assistant Add-on: PostgreSQL + TimescaleDB - #95 by edouardkleinhans
2022-04-19: DSMR Reader Add-on v1.1.2, Faster install time
Note upgrading: Due to technological changes it may be required to uninstall and reinstall the addon again (if “image does not exist” error pops up).
Changelog here
Hi Sander
It’s not clear to me whether uninstalling/reinstalling also deletes historical data.
Can you confirm we can keep the data ?
Data is kept as it’s stored in the configured postgres database.
For internal dsmr backups (don’t mean the app backup functionality of HA which works anyway) just make sure step 10 is correctly set to the backup folder: hassio-addons/dsmr_reader at master · sanderdw/hassio-addons · GitHub.
