DSMR Reader Add-on for Home Assistant
Not sure why uninstalling is needed?
after running docker pull sanderdw/ha-dsmr-reader-amd64:1.1.2
manually trough the cli, the add-on is working fine after the upgrade (worked on 2 installations for me).
In one of my two installations i’m walking into the following problem:
**Too many unprocessed readings: 318** (**47 minutes ago**)
**Day statistics are lagging behind** (**2 weeks, 5 days ago**)
I already tried Docker: (IntegrityError) null value in column "delivered_1" violates not-null constraint · Issue #1288 · dsmrreader/dsmr-reader · GitHub
But the DELETE is returning 0 rows, also SELECT returns 0 rows…
So it seems that DSMR-Reader is trying to continually inserting NULL values, which are not allowed, the TimescaleDB log does confirm that:
2022-04-20 20:29:03.881 UTC [709] STATEMENT:  INSERT INTO "dsmr_consumption_electricityconsumption" ("read_at", "delivered_1", "returned_1", "delivered_2", "returned_2", "currently_delivered", "currently_returned", "phase_currently_delivered_l1", "phase_currently_delivered_l2", "phase_currently_delivered_l3", "phase_currently_returned_l1", "phase_currently_returned_l2", "phase_currently_returned_l3", "phase_voltage_l1", "phase_voltage_l2", "phase_voltage_l3", "phase_power_current_l1", "phase_power_current_l2", "phase_power_current_l3") VALUES ('2022-04-01T19:24:00+00:00'::timestamptz, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL) RETURNING "dsmr_consumption_electricityconsumption"."id"
2022-04-20 20:29:34.680 UTC [709] ERROR:  null value in column "delivered_1" of relation "dsmr_consumption_electricityconsumption" violates not-null constraint
Anything else I can try? I’m out of options and spend some hours now :slight_smile: I compared all the GUI settings to my other installation, but there is nothing that comes to mind which is off.
@sanderdw I am receiving the following error:
Starten van de add-on is mislukt
Image sanderdw/ha-dsmr-reader-amd64:1.1.2 does not exist for addon_0826754b_dsmr_reader
What can I do to fix this? Thanks!
See my earlier post: DSMR Reader Add-on for Home Assistant - #226 by sanderdw
@sanderdw anything that comes to mind?
Your issue is a specific DSMR software issue. So my advice would be to check it at Issues · dsmrreader/dsmr-reader · GitHub or create an issue there. I’m on holiday so can’t really help out on that kind of specific issues.
Got the same issue after upgrading to latest version
U fixed this?
edit: ah indeed, deleting and reinstalling fixed it.
@sanderdw Is it now safe to update the timescale db?
Cause that gave errors earlier
I think people upgraded TimescaleDB with succes, not using it myself so better to ask here for support: Home Assistant Add-on: PostgreSQL + TimescaleDB
But you can safely try. Just shutdown the dsmr addon first to make sure you don’t corrupt the database. Afterwards upgrade TimescaleDB with a backup and see if everything goes well before starting up DSMR again.
That’s more or less what I did recently (second attempt).
I waited for TS 2.0.1 and DSMR add on 1.1.1
I stopped HA (in proxmox, where I took a backup).
Then I upgraded again. Fail.
Restore Proxmox Backup. Up and running again in 5 minutes.
When it involves manual interventions on CLI, i’ll probably never get it to work, since I quickly lose track there. So I’m hoping for an automated solution :slight_smile:
Hi @gcoupe did you fix this?
Still having problems to update
@sanderdw any ideas?
I cant upgrade my timescale db
Try to put all the databases also in the Timescale enabled listing, see Automatic updater is broken - missing libraries · Issue #18 · Expaso/hassos-addon-timescaledb · GitHub
But before you do make sure the DSMR addon is stopped.
This is my config now
databases:
  • homeassistant
  • dsmrreader
    timescale_enabled:
  • homeassistant
    timescaledb:
    telemetry: basic
    maxmemory: 512MB
    maxcpus: ‘4’
    max_connections: 20
    system_packages: []
    init_commands: []
So you say i need to put dsmrreader also in the timescale enbaled thing?
Like this:
databases:
  • homeassistant
  • dsmrreader
    timescale_enabled:
  • homeassistant
  • dsmrreader
    timescaledb:
    telemetry: basic
    maxmemory: 512MB
    maxcpus: ‘4’
    max_connections: 20
    system_packages: []
    init_commands: []
ok that did the trick ! Thx for the problem solving !
Update to 1.2.0
Where did the nice UI go?
2022-05-09: DSMR Reader Add-on v1.2.0, Support for Ingress in BETA, see changelog
Changelog here
Because of Ingress support the ‘OPEN WEB UI’ button in the addon will always try to open up the Ingress page. As it’s standard disabled for now in Configuration (ENABLE_INGRESS) you need to open up the url manually in the browser, something like http://yourhomeassistant:7777/admin or check the log for the correct url.
If you want to try out the new Ingress support you need to set ENABLE_INGRESS to on in the Configuration. After this you can use the ‘OPEN WEB UI’ as normal again and it will open up in HA internally.
If this is not working, you probably need to uninstall and install the addon again :face_with_monocle:.
Can you let me now if my explanation works out for you?
Yes, the ip:7777 works
Can you explain why i should enable ingress?
what are the benifits?
Basically it integrates DSMR Reader in HA on UI level without having to mess with ports, so security wise it’s also a little safer (when you remove the 7777 port config aswell after activating and running Ingress correctly).
See Introducing Hass.io Ingress - Home Assistant
But you don’t have to use it, you can still use the manual ip:7777 option, only downside is now that you can’t use the ‘OPEN WEB UI’ button anymore.
i enabled the ingress toggle, and webui is back :wink:
easier than, 7777
