DSMR sensor Interval
I’m using the SmartMeter add-on (DSMR) to parse data and present in Home-Assistant.
sensor
  • platform: dsmr
    port: /dev/ttyUSB0
    dsmr_version: 5
My smartmeter spits out data every single second. This gives a nice actual reading, however I’ve noticed my database is getting larger and larger. Graph loading takes about 1 minute, which is not very responsive…
Is it possible to reduce the amount of data stored to the database to 1 minute values?
I have tried scan_interval: 300 but that has no effect.
Additional, i would like to keep weekly, montly and yearly data for comparison purposes.
Thanks for any help.
Regards,
Peter
I would try excluding this sensor from the recorder. Then add a template sensor like this:
    sensors:
      dsmr_1min:
        entity_id: sensor.dummy
        value_template: "{{ states('sensor.dsmr') }}"
Using an entity_id that doesn’t exist should prevent this template sensor from updating automatically. Then use an automation to update it every minute:
automation:
  - alias: Update sensor.dsmr_1min
      platform: time_pattern
      minutes: '/1'
      service: homeassistant.update_entity
      entity_id: sensor.dsmr_1min
For the longer term data collection, I wouldn’t count on HA’s database. I don’t think it’s intended for that. Maybe use the File notification component (and an automation) to record values at the larger periods. Or maybe someone else has a better idea for that part.
Thanks for your reply.
I will first try using the exclude, template and automation sequence.
Just an idea, I could make custom sensors like:
  • daily power usage
  • weekly power usage
  • montly power usage
Then use automation to store value’s in these custom sensors right?
What do you mean by “custom sensor”?
@peter_pdj I had the same issue with a huge database because of my smart meter spitting out data out at a high interval. I found this topic and followed the advice to create a filter sensor. Followed by a service call to recorder.purge which actually cleans up the database. Hope this helps for you.
