i filled my host with my ip number of my synology.
But it isn’t copied in the text above.
So my P1 meter is connected to my synology with usb to serial. It is working with domoticz and my port is /dev/ttyUSB0 (according to domoticz) but no luck in HA at this moment
i removed the host (domoticz i manually stopped to avoid interference) i now i receive next output
17-04-20 09:33:22 ERROR (MainThread) [homeassistant.components.sensor.dsmr] error connecting to DSMR
File “/usr/local/lib/python3.5/site-packages/serial/serialposix.py”, line 244, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/ttyUSB0’
File “/usr/src/app/homeassistant/components/sensor/dsmr.py”, line 139, in connect_and_reconnect
reader_factory())
File “uvloop/future.pyx”, line 230, in iter (uvloop/loop.c:110600)
File “uvloop/future.pyx”, line 434, in uvloop.loop.BaseTask._fast_wakeup (uvloop/loop.c:114018)
File “uvloop/future.pyx”, line 146, in uvloop.loop.BaseFuture.result (uvloop/loop.c:109361)
File “uvloop/future.pyx”, line 101, in uvloop.loop.BaseFuture._result_impl (uvloop/loop.c:108900)
File “uvloop/future.pyx”, line 372, in uvloop.loop.BaseTask._fast_step (uvloop/loop.c:112669)
File “/usr/local/lib/python3.5/asyncio/coroutines.py”, line 210, in coro
res = func(*args, **kw)
File “/usr/local/lib/python3.5/site-packages/serial_asyncio/init.py”, line 410, in create_serial_connection
ser = serial.serial_for_url(*args, **kwargs)
File “/usr/local/lib/python3.5/site-packages/serial/init.py”, line 88, in serial_for_url
instance.open()
File “/usr/local/lib/python3.5/site-packages/serial/serialposix.py”, line 247, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: ‘/dev/ttyUSB0’
17-04-20 09:33:52 ERROR (MainThread) [homeassistant.components.sensor.dsmr] error connecting to DSMR
reader_factory())
instance.open()
