Hi All,
I have been playing around for a week now with HA and I love it. But I found something I don’t understand.
I just chanched to HA from domoticz and I already did use the P1-USB converter for reading the telegram from the ‘slimme meter’ and it was working fine. Domoticz calculated the power loads for eacht fase from the current and voltage.
But now in Home Assistant I don’t get the values from the current meters. (DSRM version 5) Only occasionally.
Sometimes when I select the entity it is shown that it hasnot been updating for 30 minutes or so.
All other items from slimme meter are updated every second and correct.
I have enabled debug logging in Integrations, the log is showing the telegram and there it’s visible, the amps are all 0.
Just to be sure I tested it back on the domoticz pi again and it is working fine there. The amps are alive.
Telegram:
1-3:0.2.8(50)
0-0:1.0.0(230112215412W)
0-0:96.1.1(4530303534303037353739373434363230)
1-0:1.8.1(001451.771*kWh)
1-0:1.8.2(001446.582*kWh)
1-0:2.8.1(000354.691*kWh)
1-0:2.8.2(000714.644*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.286*kW)
1-0:2.7.0(00.000*kW)
0-0:96.7.21(00008)
0-0:96.7.9(00004)
1-0:99.97.0(1)(0-0:96.7.19)(220331172457S)(0000021837*s)
1-0:32.32.0(00004)
1-0:52.32.0(00004)
1-0:72.32.0(00003)
1-0:32.36.0(00001)
1-0:52.36.0(00001)
1-0:72.36.0(00001)
2023-01-12 21:53:58.381 DEBUG (MainThread) [dsmr_parser.clients.protocol] received data:
0-0:96.13.0()
1-0:32.7.0(232.4*V)
1-0:52.7.0(230.6*V)
1-0:72.7.0(233.0*V)
1-0:31.7.0(000*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.155*kW)
1-0:41.7.0(00.097*kW)
1-0:61.7.0(00.034*kW)
1-0:22.7.0(00.000*kW)
1-0:42.7.0(00.000*kW)
1-0:62.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303332353635353334383831393137)
0-1:24.2.1(230112215002W)(02542.115*m3)
Anyone with tips how to solve this?
Thanks in advance
