DTE Energy Bridge Version 2 Scaling Issue
Anyone with a DTE Energy Bridge Version 2 notice that the units scaling is off for the power usage measurement? My energy usage is typically below 500 Watts, but the energy bridge reading in HA shows it to be 500 kilo Watts (kW)! In the code (dte_energy_bridge.py) it appears that there was a bug in the data feed that made the scale factor a bit tricky to get right but that might be no longer needed or correct for the version 2. If I can get confirmation from other version 2 owners that they are seeing the same problem I’ll submit a fix.
I have this same issue.
I’m having the same issue as well.
Screenshot%20from%202018-11-01%2020-43-34
Thanks for the confirmation, I’ll log an issue and propose a fix.
