Dual USB drives?
i Currently have a small installation on an old 3B+, with the installation on a 16 GB USB drive i had available and it’s starting to run out of space after playing with this a few months!
Before i go buying an SSD i wanted to try and move it to a 32 GB i had but i can’t get it to boot after cloning the 16GB disk over to the 32 GB with BalenEtcher (i read about this on the forum and others had success doing it this way). That’s one issue i have encountered, but i’ll have to troubleshoot that if i buy an SSD, and maybe then it’s better to just do a fresh install with a full snapshot instead.
Then i tried instead to use another 16GB USB drive as a secondary storage and wanted to move my datadisk there, but this doesn’t seems possible?
Is that only available when you use an SD card to boot from?
No matter what file format i have tried i can’t get the secondary drive to show up under the “move data disk menu”. I can see the drive under /dev/sdb (boot drive at /dev/sda), but it’s not recognized by HA it seems.
Is it possible to get dual usb drives working?
Easiest way by far would be to backup your existing setup, transfer backup to another machine. Install fresh on 32gb card and restore backup. No real point faffing about trying to transfer an OS from one disk to another when the backups work so easily.
