I’m looking for a slider with 2 value’s to consolidate min/max value’s for automation.
For example, I can control min/max value’s of my boiler temp and can use 2 seperate sliders to achieve this.
But I was wondering if there is an option for 1 UI element that can be used for both value’s.
Same thing could be used for min/max value humidity to turn on/off a humidifier.
Yes, except my thermostat only has a cold and heat option not an auto that lets you pick both set points, so I’m looking to setup a UI and automation that lets me do that on my own. The automation is easy, the UI is less so (at least for me)
Any progress on this?
I am also looking for a dual min/max slider to define the range setting for notification on my bbq pit.
Using 2 sliders, one for min and one for max looks clunky.
I am looking for a multiple interval slider - not only limited to 2 “data points”, but a number of configurable data points.
E.g. if you want to be able to specify different ranges for the cost of electricity, and you have 5 intervals:
Below 1.5
1.5 to below 2.5
2.5 to below 3.5
3.5 to below 4.5
and 4.5 or higher
For that it would be nice to be able to set a minimum and maximum value - and then a number of configurable slider points between min and max (and maybe set a step interval or have to possibility to enter the data points in an input-field) …
I’m looking for a more elegant card to visualize the state of and control some top-down bottom-up powerview shades, and a dual-selection slider would be ideal. I haven’t yet gotten into creating custom dashboard cards in Home Assistant, but this may end up being the thing that motivates me to get over the initial setup hurdle.
Throwing a hail mary here: Does anyone have a solution for this? Im trying to create a single slider (with two points, min/max) for a 24hour period with start and stop and dont want two different sliders
