Hello everyone, this is my firts post here but I’ve read a lot while configuring lots of devices in HA. Sorry for my bad english.
I’m trying to use some Sonoff DUALR3 powering motor-blinds with mechanical endstops.
Following some guides on the web (GPIO pinout, BL0939 integration, switch input integration, lambda controls for testing with on-board button and interlock function) I managed to make it work, but with some questions about how it does:
To have the sensor reading fast enough to detect endstops i have to set it to 500ms.
This is causing 4 entries per seconds on the logs which doesn’t sound really efficient.
I see that also wiki example (Current Based Cover - ESPHome ) is using this method.
As I don’t need the current to be measured when relays are not triggered, is there a way to force the sensor update at 500ms (or less) when at least 1 relay is on and disable readings when both relays are off?
Here part of the config:
Sensor set-up:
- platform: bl0939
update_interval: 500ms
current_1:
current_2:
Cover set-up:
cover:
- platform: current_based
device_class: blind
open_sensor: open_current
open_moving_current_threshold: 2.1
open_obstacle_current_threshold: 2.5
open_duration: 35s
open_action:
- switch.turn_on: open_cover
close_sensor: close_current
close_moving_current_threshold: 2.1
close_obstacle_current_threshold: 2.5
close_duration: 35s
close_action:
- switch.turn_on: close_cover
stop_action:
- switch.turn_off: close_cover
- switch.turn_off: open_cover
obstacle_rollback: 2%
start_sensing_delay: 1.0s
max_duration: 37s
Current measurement is “internal” so value doesn’t transfer to HA and occupy history space, if that’s what you mean. But in any case measurement are recorded into history only when changed, not at every measurement. So when cover current is zero that value is recorded only once, not every 0.5 s. - until it changes, of course.
Thank you for your reply,
I know that as I disabled sensor names on purpose to remove them from Home Assistant.
I was thinking about resource waste due to continuos sensor monitorin, am I wrong? Is this the best way to make it work?
No, in esphome yaml you set current sensors as “internal: true”. That way they won’t show in HA:
sensor. In below example all sensors are internal - i think that “name” is not needed either… names are just “leftovers” from my testing, when i temporarily created voltage and current sensors available in HA for monitoring…
- platform: ade7953
irq_pin: GPIO16
voltage:
name: Shelly 2.5 Mains Voltage
internal: true
filters:
- throttle: 5s
current_a:
name: Shelly 2.5 Open Current
internal: true
current_b:
name: Shelly 2.5 Close Current
internal: true
update_interval: 0.5s
I didn’t know about the internal: true
option. That’s useful!
But, my question was about the ESP32 device, not the HA instance (which is on a server and doesn’t have performance issues).
Also, is there a way to log button press, but not sensor readings? Do I have to specify platforms?
You said for both current sensor that " This is causing 4 entries per seconds on the logs which doesn’t sound really efficient." internal is the solution for this.
Regarding log: there are a couple of options, see logger component.
This example sets all logs to “verbose”, only switch components to “info”:
logger:
level: verbose
logs:
switch: info
I guess that you could try:
logger:
logs:
sensor: none
This way sensors won’t be logged.
But i’m not sure what you’ll gain with it… it’s just an internal esphome’s logger, which is constantly overwritten.
dgolzman
(Damian Golzman)
March 22, 2023, 3:33pm
7
Could you please pass me the code for esphome with which you managed to get the current and voltage measurements?
Styx85
(Christoph Berliner)
June 6, 2024, 7:41am
8
So if anyone can use it, here is a full code example for a current based cover control: Sonoff Dual R3 v2.x
# Pin Function
# GPIO13 Status LED (blue/inverted)
# GPIO00 Push Button (inverted)
# GPIO27 Relay 1 / LED 1 (red)
# GPIO14 Relay 2 / LED 2 (red)
# GPIO32 Switch 1 (inverted)
# GPIO33 Switch 2 (inverted)
# GPIO25 power sensor UART Tx
# GPIO26 power sensor UART Rx
substitutions:
friendly_name: Wohnzimmer Rolladen
devicename: wz-rolladen
fritz: wohnzimmer-rolladen-sonoffdualr3-esphome
open_duration: 45s
close_duration: 45s
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
area: Wohnzimmer
project:
version: '1.0'
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: DEBUG
logs:
sensor: WARN
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
password: !secret esphome_api_password
wifi:
ssid: !secret wifi_iot_ssid
password: !secret wifi_iot_password
use_address: ${fritz}.fritz.box
ap:
ssid: "${devicename} Fallback Hotspot"
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
# To have a "next url" for improv serial
web_server: ## can use when OTA does not work
port: 80
# Sync time with Home Assistant
time:
- platform: homeassistant
uart:
tx_pin: GPIO25
rx_pin: GPIO26
baud_rate: 4800
parity: NONE
stop_bits: 2
- platform: bl0939
voltage:
internal: true
filters:
- throttle: 5s
current_1:
disabled_by_default: True
current_2:
active_power_1:
filters:
- throttle: 5s
active_power_2:
filters:
- throttle: 5s
energy_1:
filters:
- throttle: 15s
energy_2:
filters:
- throttle: 15s
energy_total:
filters:
- throttle: 15s
- platform: wifi_signal
update_interval: 90s
entity_category: "diagnostic"
- platform: uptime
update_interval: 300s
button:
- platform: restart
light:
- platform: status_led
pin:
number: GPIO13
inverted: True
internal: True
switch:
- platform: gpio
pin: GPIO27
internal: true
interlock_wait_time: 350ms
interlock: &interlock_group [relay1, relay2]
restore_mode: always off
- platform: gpio
pin: GPIO14
internal: true
interlock: *interlock_group
binary_sensor:
- platform: gpio
# internal: true
pin:
number: GPIO32
mode:
input: True
pullup: True
inverted: True
filters:
- delayed_on_off: 50ms
on_press:
then:
- lambda: |
if (id(rolladen).current_operation == COVER_OPERATION_IDLE) {
// Cover is idle, check current state and open cover.
id(rolladen).make_call().set_command_open().perform();
else {
// Cover is opening/closing. Stop it.
id(rolladen).make_call().set_command_stop().perform();
# on_press:
# - switch.turn_on: relay_1
# on_release:
# - switch.turn_off: relay_1
- platform: gpio
# internal: true
pin:
number: GPIO33
mode:
input: True
pullup: True
inverted: True
filters:
on_press:
then:
- lambda: |
// Cover is idle, check current state and close cover.
id(rolladen).make_call().set_command_close().perform();
else {
# on_press:
# - switch.turn_on: relay_2
# on_release:
# - switch.turn_off: relay_2
- platform: gpio
pin:
number: GPIO00
mode:
input: True
pullup: True
inverted: True
icon: 'mdi:radiobox-blank'
filters:
- delayed_on: 50ms
on_press:
- switch.toggle: relay1
cover:
start_sensing_delay: 800ms
open_sensor: open_current_sensor
open_moving_current_threshold: 0.2
open_obstacle_current_threshold: 2.0
open_action:
- switch.turn_on: relay1
open_duration: ${open_duration}
close_sensor: close_current_sensor
close_moving_current_threshold: 0.2
close_obstacle_current_threshold: 2.0
close_action:
- switch.turn_on: relay2
close_duration: ${close_duration}
stop_action:
- switch.turn_off: relay2
- switch.turn_off: relay1
obstacle_rollback: 30%
max_duration: 55s
##BLE uses too much resources if logger is not restricted ##
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
I had to restrict the logger to get stability with BLE activated. Without BLE you probably can use standard logging.
rodri2566
(Rodrigo)
September 11, 2024, 12:33pm
9
hey, @Jethro97 , sorry to bother, would you mind sharing your full config? I’m trying to follow your steps but I’m missing something.
Thank you in advance!
Sorry for late reply, sure!
substitutions:
dn: "01-curtain"
ldn: Curtain
coverid: curtain1
# ------- FIXED ITEMS ------- #
esphome:
platform: ESP32
board: esp32dev
# ------- LOGGING ------- #
logger:
baud_rate: 0
level: info
# ------ HOME ASSISTANT DEFAULT CONFIGURATIONS ------- #
api:
encryption:
key: "*****"
ota:
- platform: esphome
password: "*****"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 10.10.12.xxx
gateway: 10.10.12.1
subnet: 255.255.255.0
# ------SENSORS ------- #
uart:
tx_pin: GPIO25
rx_pin: GPIO26
baud_rate: 38400
parity: EVEN
- platform: cse7761
current_1:
internal: true
current_2:
internal: true
name: $ldn WiFi Sensor
update_interval: 120s
text_sensor:
- platform: wifi_info
mac_address:
icon: mdi:wifi
# ------- STATUS LED ------- #
#status_led:
# pin:
# number: GPIO13
# inverted: yes
# ------- ON_BOARD PHISYCAL BUTTON ------- #
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: true
on_press:
then:
# logic for cycling through movements: open->stop->close->stop->...
- lambda: !lambda |-
if (id($coverid).current_operation == CoverOperation::COVER_OPERATION_IDLE) {
// Cover is idle, check current state and either open or close cover.
if (id($coverid).position == COVER_CLOSED) {
auto call = id($coverid).make_call();
call.set_command_open();
call.perform();
} else {
call.set_command_close();
call.perform();
} else {
call.set_command_stop();
call.perform();
# ------- OPENING PHISICAL COMMAND ------- #
- platform: gpio
pin:
number: GPIO32
mode: INPUT_PULLUP
inverted: True
name: "$ldn Opening Command"
on_press:
then:
# Logic for cycling trough movements: open -> stop -> open -> ...
// Cover is idle. Open it.
call.perform();
} else {
call.perform();
# ------- CLOSING PHISICAL COMMAND ------- #
- platform: gpio
pin:
number: GPIO33
mode: INPUT_PULLUP
inverted: True
name: "$ldn Closing Command"
on_press:
then:
# Logic for cycling trough movements: close -> stop -> close -> ...
// Cover is idle. Close it.
call.perform();
} else {
call.perform();
# ------- POWER INTERLOCKED RELAYS ------- #
switch:
- platform: gpio
pin: GPIO27
interlock: &interlock [open_cover, close_cover]
- platform: gpio
pin: GPIO14
# ------- COVER CONFIGURATION ------- #
cover:
device_class: blind
open_moving_current_threshold: 0.5
open_obstacle_current_threshold: 3.0
open_duration: 30s
open_action:
close_moving_current_threshold: 0.5
close_obstacle_current_threshold: 3.0
close_duration: 30s
close_action:
stop_action:
start_sensing_delay: 1s
max_duration: 35s
