I installed the Duck DNS add-on. Setup an account on Duck DNS did the port forwarding etc…
Now in the add on page I am trying to configure in the Options page, I replaced “null” with my token and null under domains with my domain. After I do this I can’t save the new configuration, the button is grayed out. What am I missing?
Yes! Since you are trying to reach your Hassio at port 8123, you have to forward port 8123 to your device running Hassio. And then by connecting to domain.duckdns.org:8123 you should be able to reach your Hassio.
All up and running, any tips for the let’s encrpyt add-on? I enabled it added my email and domain as before and changed my port forward to 443 - 8123 anything else?
No luck, do i have to create an account on lets encrypt or anything? I feel as though I have missed something along the way trying to piece together the steps from Hassbian guides… seeing this error:
2017-07-28 20:02:45 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 278, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 274, in aiohttp._http_parser.HttpParser.feed_data (aiohttp/_http_parser.c:4364)
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
No no! Here is my Let’s Encrypt config. First, you have to forward port 80 and 443 to your pi. You have to stop every other Add-On(!) (SSH, SAMBA, etcetera).
Then fill out the config an start the Let’s Encrypt Add-On.:
Trying to to the same but the add-on will not start.
I have stopped all other addons. My router NAT rules are:
80 --> ip of hassio pi port 80
443 --> ip of hassio pi port 8123
I moved from AIO config to hass.io. The DuckDN / Let’s Encrypt setup was working fine.
I hope you have some suggestions.
All this talk about port forwarding is confusing. I thought, because this is the Hass.io DuckDNS Add-On with built in Lets Encrypt, you only need to forward one port on the router (443>8123). That’s all I did and I have access via the internet. Tell me if I’m missing something else.
Similarly, there’s talk above about turning off other add-ons (samba, ssh, etc.), the turning them back on. Not sure why that’s required, but maybe that’s why I have managed to hose my Samba shares? Still trying to figure out how to reconnect so I can try to edit my yaml files, etc.
Any advise on how to fix Samba now that encryption is on is appreciated.
I see you have a working config. Can you confirm if the xxx in the domains part of the config should include the “http://” part of the URL or just the domain name
Also the same for the Home Assistant config for “Base URL” should it include the “http://” bit
Many thanks for clarifcation as I have been struggling to make this work for a couple of days now
I am also struggling with this. I noticed in my Duck DNS log inside the Duck DNS component it shows the following error
starting version 3.2.2
# INFO: Using main config file /data/workdir/config
+ Account already registered!
Tue Oct 31 19:10:43 GMT 2017: KO
Processing http://mydomainname.duckdns.org
+ Signing domains...
+ Generating private key...
+ Generating signing request...
end of string encountered while processing type of subject name element #1
problems making Certificate Request
Ok just to answer my own question the problem was I was including the “http://” in my domain name for the Duck DNS component config.
when I leave out the “http://” it has finally generated the keys
Tue Oct 31 19:18:50 GMT 2017: OK
31.52.255.74
NOCHANGE
Processing mydomainname.duckdns.org
+ Creating new directory /data/letsencrypt/mydonamename.duckdns.org ...
+ Requesting challenge for mydomainname.duckdns.org...
OK + Responding to challenge for mydomainname.duckdns.org...
OK + Challenge is valid!
+ Requesting certificate...
+ Checking certificate...
+ Done!
+ Creating fullchain.pem...
+ Done!
i´ve just found out that my ISP here in brazil are blocking ports 443 and 80 for whoever isn´t a companie, they´re trying to avoid common people to run server on their own, I don´t know if there´s any other way around this, but for now I won´t have way to setup the let´s encrypt
