Hello everyone!
Newly installed and configured Duck DNS
domains:
- xxxxxx-ha.duckdns.org
token: YYYYYYYY-YYYY-YYYY-YYYY-YYYYYYYYYYYY
aliases: []
lets_encrypt:
accept_terms: true
algo: secp384r1
certfile: fullchain.pem
keyfile: privkey.pem
seconds: 300
Cyclically gives the same message in the following logs
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service duckdns: starting
s6-rc: info: service duckdns successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Generating account key...
+ Registering account key with ACME server...
+ Fetching account URL...
+ Done!
[11:47:50] INFO: Starting DuckDNS...
[11:47:51] INFO: Renew certificate for domains: xxxxxx-ha.duckdns.org and aliases:
+ Creating chain cache directory /data/workdir/chains
Processing xxxxxx-ha.duckdns.org
+ Creating new directory /data/letsencrypt/xxxxxx-ha.duckdns.org ...
+ Signing domains...
+ Generating private key...
+ Generating signing request...
+ Requesting new certificate order from CA...
+ Received 1 authorizations URLs from the CA
+ Handling authorization for xxxxxx-ha.duckdns.org
+ 1 pending challenge(s)
+ Deploying challenge tokens...
grep: unrecognized option: b
BusyBox v1.36.1 (2024-06-10 07:11:47 UTC) multi-call binary.
Usage: grep [-HhnlLoqvsrRiwFE] [-m N] [-A|B|C N] { PATTERN | -e PATTERN... | -f FILE... } [FILE]...
Search for PATTERN in FILEs (or stdin)
-H Add 'filename:' prefix
-h Do not add 'filename:' prefix
-n Add 'line_no:' prefix
-l Show only names of files that match
-L Show only names of files that don't match
-c Show only count of matching lines
-o Show only the matching part of line
-q Quiet. Return 0 if PATTERN is found, 1 otherwise
-v Select non-matching lines
-s Suppress open and read errors
-r Recurse
-R Recurse and dereference symlinks
-i Ignore case
-w Match whole words only
-x Match whole lines only
-F PATTERN is a literal (not regexp)
-E PATTERN is an extended regexp
-m N Match up to N times per file
-A N Print N lines of trailing context
-B N Print N lines of leading context
-C N Same as '-A N -B N'
-e PTRN Pattern to match
-f FILE Read pattern from file
-r Recurse
-i Ignore case
I need SSL/TLS but it seems that the script is not compatible with my Linux and can’t process the command
Can anyone help me with such issue?
