Duck DNS and local IP access
It seems to be fairly well documented that you need DNS loopback to access HA after DuckDNS has been configured.
I have ports forwarded on the router and I can access HA via the LAN and WAN. The current configuration will call the DuckDNS servers even if I am connected to my LAN. I would like for the iOS app to communicate directly to HA when on the LAN. My web browser can access https://192168.x.x (local address) but there is no certification (as expected). It seems to be the same within iOS app but the app does not let me advance to HA. Is there an easy method to pull the certification so I can access my local HA without certification issues?
Your only option is to use a reverse proxy such as NGINX, this way you get http local and https remotely.
Thanks for that. the ā€˜NGINX Home Assistant SSL proxyā€™ add on seems to be the better option. ā€˜Nginx Proxy Managerā€™ also requires ā€˜MariaDBā€™ add-on which seems pointless for my basic application. Just need to figure out how to get this setup.
I have no clue how to configure the add-ons (I run Home Assistant Container), but I assume the docs for the add-ons should cover it fairly well.
I have used the addon Nginx home assistant SSL Proxy for such case ( Http local and https remote access) in my Supervised install
Thatā€™s great to know, thanks! Iā€™ll research into this setup.
Thank you all for your help.
I can confirm I have ā€˜DuckDNSā€™ and ā€˜Nginx home assistant SSL Proxyā€™ add-ons configured so I can access HS remotely via HTTPS and HA locally with HTTP.
If you follow both the instructions in the documentation of those add-ons but comment out (#) or delete the following in configuration.YAML. youā€™ll gain access as intended
http:
base_url: https://yourDNS address.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: True
login_attempts_threshold: 3
I added the last two entries for security reasons
This link is spot-on:
Bringing this back from the dead, 2 years laterā€¦ Iā€™m trying to follow the instructions given here, in the NGINX documentation, the DuckDNS documentation, and the link posted above. Unfortunately, nothing seems to quite work for me and I suspect itā€™s because of my current setup.
I canā€™t forward port 443 in my router because I have another server using that one. When I attempt another port, nothing quite works right - I get connection rejected/reset messages for my local IP in the app, security warnings in the desktop, and the external address stops working completely.
Anyone willing to help me sort this mess out?
You donā€™t need nginx to do this. If ha is doing ssl on 8123 already, all you need is to install the dnsmasq add on and configure an A record for your home assistant server using the fqdn you chose for duckdns. Then devices inside your LAN will be able to access it securely, by name, without hairpinning your firewall. For external access, just do a nat for 8123 instead of trying to port forward 443 to 8123.
If you need more info, this video should help.
Okay so itā€™s possible Iā€™m partially hosedā€¦ Iā€™m using Ubiquiti products and, from what I can gather from various forum posts, itā€™s an absolute and colossal PITA to create NAT rules for their equipment. The video instructs us to change the DNS address of the DHCP server to the IP of the HA server; I currently have the primary and secondary set to 4.4.4.4 and 8.8.8.8, respectively. Should I just set the primary IP to that of my HA instance and the secondary to 4.4.4.4 so other devices that donā€™t care about HA can fall back to the other IP?
Iā€™m also using Ubiquiti gear, and itā€™s quite simple to create NAT rules. In fact, itā€™s so simple that I have automated them so they turn on and off based on whether not not everyone is home. That way, when everyone is at home and there is no need for remote access to HA, the firewall rules are turned off to lessen my attack surface.
That aside, what I did was to only use my HA server for primary DNS and left secondary DNS blank. There is no ā€œother devices that donā€™t care about HAā€. Fallback - for anything on the network - would only take place when and if your HA server became unavailable for some reason. Since I run my gear on reliable hardware, I donā€™t worry about that. Being able to control my DNS resolution is far more important to me.
Even beyond that, though, Iā€™m not sure what the 4.4.4.4 IP is. Itā€™s likely not what you think it is, either.
Oh, thatā€™s great news! I simply cannot figure out how to make it happen in the Unifi settings. Would you mind sharing your config/setup?
Yip, I thought this was the alternate Google DNS server but itā€™s 8.8.4.4! Thatā€™s what I get for going off memoryā€¦
