I’ve been using Duck DNS for about 2 years now without any issues but over the last week I cannot access Home Assistant remotely on the external IP, I’ve confirmed the IP address on Duck DNS is the same as my public IP address both on Duck DNS and if I use “What’s My IP” in a browser, and it resolves correctly on my PC and if I ping the DNS name I get replies.
Nothing has changed on my router / firewall for probably 8 months so I’m pretty certain that’s not the issue.
I have not touched the Letsencrypt configuration at all since it was initially setup.
Letsencrypt version is 4.11.0
DuckDNS version is 1.13.0
System info below
Letsencrypt log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] file-structure.sh: executing...
[cont-init.d] file-structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[11:27:20] INFO: Selected http verification
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator standalone, Installer None
Cert is due for renewal, auto-renewing...
Renewing an existing certificate
Performing the following challenges:
http-01 challenge for XXXX.duckdns.org
Waiting for verification...
Challenge failed for domain XXXXX.duckdns.org
http-01 challenge for XXXXX.duckdns.org
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: XXXXXX.duckdns.org
Type: connection
Detail: Fetching
http://XXXXX.duckdns.org/.well-known/acme-challenge/zReI1q-osinzEH2LJXiF4qQSu56h6sqIQ8W9thodixc:
Timeout during connect (likely firewall problem)
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you're using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Hi @tom_I thanks for the reply but I don’t really understand what you mean, I have below in my DuckDNS config file. Has something changed on Home Assistant recently with Letsencrypt and DuckDNS?
Ah I didn’t know that, yes I had both installed (always have though) I have uninstalled LetsEncrypt now and restarted Home Assistant but still cannot connect
There are no errors in the DuckDNS log file and the IP address its detecting is correct?
Although something I’ve noticed now is that I actually can’t ping the hostname if I’m on an internet connection not routing via my home router so I’m wondering if it is not perhaps something like a policy change with my ISP where they now block incoming connections, its the only other thing I can think of.
Sorry, I meant I didn’t think it was the browser cache issue. I’ve cleared it and the issue persists.
But something else I’ve tried now is connecting via my wife’s mobile phone (as a hotspot) which is a different ISP to what I use for my mobile and who are also our fiber provider and it then connects through my DuckDNS hostname so I’m pretty convinced at this point that my ISP may no longer be allowing either inbound NAT or incoming connections, its the only logical thing I can think of.
EDIT, actually it cannot be that either because via her ISP the connection into our network would still go via our fiber provider.
@tom_I what I meant with the issue persists is that after clearing the browser cache I am still getting the same error: “Unable to connect to Home Assistant”
My apologies I should have been clearer with my reply.
