I have succesfully using Home Assistant with Duck DNS for a long time. Now I’m installing Home Assistant on a different device (raspberry pi 4).
On this new raspberry Duck DNS should also work. But I have problems. What have I done so far:
In my router I have changed the port forwarding to the local ip of the raspberry
In the Duck DNS account I have changed nothing, so I use the same domain name (Duck DNS on the old pc is stopped)
The certificates are not created and I get the next log information of Duck DNS:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
# INFO: Using main config file /data/workdir/config
+ Generating account key...
+ Registering account key with ACME server...
+ Fetching account URL...
+ Done!
[11:20:54] INFO: OK
<public ip address>
NOCHANGE
[11:20:54] INFO: Renew certificate for domains:< my domain name>.duckdns.org and aliases:
+ Creating chain cache directory /data/workdir/chains
Processing < my domain name>.duckdns.org
+ Creating new directory /data/letsencrypt/< my domain name>.duckdns.org ...
+ Signing domains...
+ Generating private key...
+ Generating signing request...
+ Requesting new certificate order from CA...
+ Received 1 authorizations URLs from the CA
+ Handling authorization for < my domain name>.duckdns.org
+ 1 pending challenge(s)
+ Deploying challenge tokens...
OK + Responding to challenge for < my domain name>.duckdns.org authorization...
+ Cleaning challenge tokens...
OK + Challenge validation has failed :(
ERROR: Challenge is invalid! (returned: invalid) (result: ["type"] "dns-01"
["status"] "invalid"
["error","type"] "urn:ietf:params:acme:error:dns"
["error","detail"] "DNS problem: SERVFAIL looking up TXT for _acme-challenge.< my domain name>.duckdns.org - the domain's nameservers may be malfunctioning"
["error","status"] 400
["error"] {"type":"urn:ietf:params:acme:error:dns","detail":"DNS problem: SERVFAIL looking up TXT for _acme-challenge.< my domain name>.duckdns.org - the domain's nameservers may be malfunctioning","status":400}
["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/...../......"
["token"] "......................."
["validated"] "2021-08-14T09:21:05Z")
[11:26:10] INFO: OK
<public ip address>
NOCHANGE
Did you specify this somewhere?
That challenge won’t work with duckdns, it only work with custom domain names where you have control over the Authoritative DNS for that domain.
This is the first time that I’ve seen duckdns down. Each time I go there, it shows online. I was really concerned that it was just me - until I saw this thread of course.
Same problem here. I’m having problems accessing my instance from outside my network all day long. Hopefully this gets resolved. Never had problems with duckdns. Good to know it’s not just me.
Duckdns seems to be under DDOS attack (or maybe another issue) for the last 24 hours or so. Nothing we can do on our side, nothing they seem to do on their side.
My proxymanager was messed up not really bad but annoying. One day the web app was reset to default no proxy. But everything keept working. Now i tough ill do it today removed all the proxys from the database and ssl files started over and now this “challenge error” pffff so you’re not alone
I did an install of Duckdns on my HA Home Assistant Core 2022.6.7 and followed the instructions. But unfortunately I got the same error:
+ Account already registered!
[09:51:23] WARNING:
[09:51:24] INFO: Renew certificate for domains: xwijk.duckdns.org and aliases:
Processing <my sub domain>.duckdns.org
+ Handling authorization for < my sub domain>.duckdns.org
ERROR: deploy_challenge hook returned with non-zero exit code
After add the text to my configuration file and restart of HA I also got the next error logging:
The system cannot restart because the configuration is not valid: Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem' not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 9).
The system cannot restart because the configuration is not valid: Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/config/ssl/fullchain.pem' not a file for dictionary value @ data['http']['ssl_key']. Got '/config/ssl/privkey.pem'. (See /config/configuration.yaml, line 9).
I’ve got the same problem using 2022.7. I install duckdns then edit the config. once I start duckdns the log shows ERROR: deploy_challenge hook returned with non-zero exit code. I’ve uninstalled and reinstalled, but get same error.
One thing I noticed in the log:
INFO: Renew certificate for domains: veejur-home.duckdns.org and aliases:
Apparently when you copy the token from duckdns, it copies the first space. When you paste it into the configuration file, you don’t see it because it is hidden and shows all dots. Even when you click the eye to show it, it’s tough to see the space given the font.
Make sure there is no space at the beginning of the token.
