I am new on this. Trying to configure Duck Dns I have this error
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
INFO: Using main config file /data/workdir/config
Account already registered!
[18:50:32] WARNING: KO
**[18:50:32] INFO: Renew certificate for domains: and aliases: ** # INFO: Using main config file /data/workdir/config ERROR: domains.txt not found and --domain not given
[18:55:35] WARNING: KO
The same thing that you are expecting with let encrypt addon. To get you a ssl cert.
This addon is doing the same thing, it is simpler to set up and it’s using different domain. And that is it. It copy/paste of let encrypt addon but it is easier to set up.
